Mysterious Coolant Leak
Hi, I have a V36 sedan with 111k miles.
The coolant leak problem started five to six months ago, where I have been noticing small coolant puddles on the ground after I start the engine in the morning.
I replaced both the upper and lower radiator hoses and several heater hoses but it did not solve the problem.
Today I did a routine oil change and decided to run the engine without the plastic undercover to see if it leaked coolant and identify the leak location.
The coolant is leaking near an area behind the water pump is located. It is a strange area for coolant to leak.
Anyone has any idea why coolant is leaking from this area? And also any recommendations for a fix?
Video of leak location:
https://imgur.com/po0ri2z
Image of where the leak is spreading (from under the car):
https://imgur.com/1L6K5Aj
Image of possible leak origin (used endoscope to reach location):
https://imgur.com/YyU4NKj
looks like the water pump is leaking from the weep hole. btw why are you using that green coolant? shouldn't your vehicle take the 50/50 premixed blue coolant. there are additives and lubricants in certain types of coolants that manufacturers specify for in their vehicles.
tite_tite
69
08-26-2024 12:37 PM
Racindaddy
01-03-2017 09:10 PM
