coolant /radiator issues
Old 08-08-2019, 11:14 PM
G37sPhoton
G37sPhoton's Avatar
Hey all,
So my daughter borrowed my car.....she said she was idling at drive tru window and smoke came out from hood(steam) ... she drove a little and car temp gauge started to climb...she was in a no cell area....she stopped , idled and then drove about 1/4 or less of a mile and car engine light came on and then she stopped, car idling ...then tried driving again and car jerked and was barely moving....pulled over and parked it...finally had a signal and called me...i drove out and saw coolant over engine bay and toward the windshield ....
I poured water in rad, as they were closing and car gets towed if left etc...and as I poured about a gallon plus , I heard it spilling below....started it, idled no issues , smooth , but within 1 mile it started to climb...so pulled over, turned off, waited a few mins...and started again...same thing ...addded more water , same scenario but managed to get to another area where it could be left overnight. Guessing it's a hose, clamp or both , but wanted any input on what it may be and if it's a DIY type fix, cost etc...car has 120k had coolant flushed last summer , the hoses are 120k miles on them....i heard the fan on when idling but as I drove and got 30+ the temp would rise...some reading said to turn heater to high...but I had a.c. on hoping it would help....all that aside, I hope no damage from the drive I did...thanks all for any help/input
Old 08-09-2019, 01:12 AM
JSolo
Just say no!!!!!
JSolo's Avatar
There's several plastic couplers. They eventually fail. I believe they're on the side(s) of the engine. It's a $5 part that should of been metal to begin with!@#
Advise your daughter not to drive any car if the temp is rising. Good way to cause engine damage.
G37sPhoton (08-09-2019)
Old 08-09-2019, 05:41 AM
Surfnazi
Surfnazi's Avatar
Either lower core of radiator has crack or you blew out lower hose.
Old 08-09-2019, 08:25 AM
G37sPhoton
G37sPhoton's Avatar
Thanks , will get under and try to see what I can and hoping is the plastic pieces as that would be the least expensive etc but for a while as she told me about the stuttering symptoms ...i thought...oh no....rear timing seal....and yeah ....had a talk , again, about what to look at re warnings ....
Old 08-09-2019, 12:24 PM
G37sPhoton
G37sPhoton's Avatar
Hey Jsolo- I think your dx was on point , at least I hope this is it...and if so...is this an unclamp for both hoses , replace the coupler and clamp back? Please tell me it's that easy ....first pic for reference on location , it's near windshield on passenger side
Old 08-09-2019, 12:52 PM
JSolo
Just say no!!!!!
JSolo's Avatar
That's quite the gusher!
I had this saved in my ebay cart - https://www.ebay.com/itm/NISSAN-INFI...A/362625786528 , but never got around to buying it. That was actually one of the maintenance things I planned for this fall (when doing the drain/fill). Won't be doing anything to it this fall. Car is sold
G37XS13 (08-09-2019)
Old 08-09-2019, 01:10 PM
antirice
antirice's Avatar
You can get a metal coupler at Oreily's for about $6.
The OEM plastic coupler is a "MUST replace" item for your car's very first coolant service. Absolutely shameful Nissan used such inferior part, which could potentially lead to engine damage and driver being stranded.
Old 08-09-2019, 02:47 PM
JSolo
Just say no!!!!!
JSolo's Avatar
Even better and more readily available. Nissan probably saved 25¢ by going plastic vs aluminum. Actually, many cooling parts are plastic these days, including even the radiator. Built in obsolescence?
Old 08-09-2019, 03:42 PM
saywat?
saywat?'s Avatar
oh the orielys route sounds nice. anyone know which coupler from there is the one we need? ima do this as preventive.
Old 08-09-2019, 03:58 PM
G37sPhoton
G37sPhoton's Avatar
That's actually a nice replacement and didn't know you sold your car....so updating hopefully?
Old 08-09-2019, 04:06 PM
G37sPhoton
G37sPhoton's Avatar
I see that now, man what a way for a manufacturer to skimp ....maybe they were thinking on the weight savings of plastic vs metal ....and oreilly it is then....the amazon one looks good too
Old 08-09-2019, 04:07 PM
antirice
antirice's Avatar
I think this is the one I got 3 years ago. Looks like they jacked up the price quite a bit.
Maybe OP can confirm if that's the right size (3/4 inch).
https://www.oreillyauto.com/detail/b.../4529082?pos=0
Old 08-09-2019, 04:10 PM
G37sPhoton
G37sPhoton's Avatar
That looks to be correct ....will confirm later but how many of these are there in our cars? Just the one?
Old 08-09-2019, 06:37 PM
OldG2NewG
OldG2NewG's Avatar
Yes it's just one
Old 08-09-2019, 09:24 PM
G37sPhoton
G37sPhoton's Avatar
So yeah that's the right size and one of the oreilly stores will have it in stock tomorrow ....so my next question is do I do a normal drain, well semi normal, finish draining what's in there and then fill etc ? I'm buying the green coolant as that's the one that has been in there all along ...and no issues....i see a few vids on how to do a drain and fill so will follow those ...
Quick Reply: coolant /radiator issues
