2JZ Swap N G37 Possible?
Hi everyone, just bought a 08 G37S recently with 100k miles. I recently replaced all the fluids, 4x o2 sensors, 2x MAF, and both Cats on the exhaust. I am contemplating in replacing the current engine with a 2JZ GTE setup. Just curious is it possible in a G37, since I noticed alot of swaps are common in G35 with CD009 trans w/2JZ adapter plate? Are the G35 motor mounts the same in G37 location? Any help is appreciated...
I can't directly answer your question but I can say anything is possible. Just bring cubic dollars.
I have to wonder if there is enough front-to-back room to squeeze an inline-six in there.
With that money you can build a motor for boost and have the same or even more fun with less headaches getting the 2j to run....i hear the wiring is expensive. .if you want everything to work properly.
TeRRoRiFiC35
04-06-2011 10:51 PM
IcebergG
18
07-04-2009 02:44 PM
