08 G37S slow shifting, 5AT all gears
Old 07-02-2019 | 12:19 PM
SaskG37S's Avatar
SaskG37S
Like the title says. It seems to be lazy going into and out of all gears, so I replaced the fluid and added some Lubegard, and I thought it had made a difference at first but it's still slow. Makes me think it's a pressure problem since it doesn't seem to be any specific gears.
I had the Trans pan off and there wasn't anything shocking in there. The oil that came out was pretty dark for sure. Never had any other problems with the trans, and I don't really have the tools to do a proper pressure test myself. It seems to have the issue whether in D or DS modes. There are no check engine lights or anything. I have a code reader but just a basic one.
I'm mostly curious if anyone else has had a similar issue or might know what's going on? I was really hoping it was just a fluid problem but it seems to be more than that.
Old 07-02-2019 | 06:56 PM
Surfnazi's Avatar
Surfnazi
You should just stick with j or smatic fluid only. Drain it and refill it with only Nissan trans fluid
Old 07-03-2019 | 09:25 PM
SaskG37S's Avatar
SaskG37S
It was refilled with Castrol Transmax synthetic. It’s compatible with Nissan Matic J and S.
Old 07-03-2019 | 10:56 PM
OldG2NewG's Avatar
OldG2NewG
Lol second thread today about trans fluids.
USE NISSAN FLUIDS ONLY.
No compatibles.
just Nissan.
The end
Old 07-04-2019 | 12:32 PM
Conboss's Avatar
Conboss
^^ Yes. I work at Canadian tire and the Castrol stuff says it works in all vehicles. It WORKS, that's it. It won't help with anything else. Do what they said
Old 07-04-2019 | 12:52 PM
SaskG37S's Avatar
SaskG37S
Seems like many other members of this board have used compatible fluids without problem..... Also where I live the super special magic Matic S fluid is $60/quart, which is completely ridiculous imo. Ebay has it but I'll have to wait a while. Another shop said that it might just be something innocuous like dirty MAF's, which I'll check tonight.
I'll do the MAF's later and if that doesn't work then might change the fluid again. I'll update this thread when I know more. Thanks for the input folks.
Old 07-05-2019 | 09:44 AM
SaskG37S's Avatar
SaskG37S
Cleaned the CAI's, filters, MAF's, and throttle bodies, then reset the ECU. Feels a bit snappier but I'm still feeling the slow shifting too, especially 1-2. Guess I'll be scouring for some Matic S.
Old 07-06-2019 | 07:19 PM
Surfnazi's Avatar
Surfnazi
Nissan trans really have issues with non Nissan trans fluid
Old 07-06-2019 | 08:10 PM
carguy87's Avatar
carguy87
Yes, like others mentioned (since two of my three cars use Matic S) you can tell the car doesn't like it. Do at least two drain-refills to get most of the fluid out. Depending on the car's history the issue may or not be caused by non-OEM fluid alone.
Old 07-08-2019 | 10:24 AM
SaskG37S's Avatar
SaskG37S
Genuinely appreciate the feedback folks. I found a place in town to get the Matic S for not too much $$ so I'll be draining and refilling this weekend. Lesson learned on my end.
BTK
19
03-19-2014 03:37 PM
ThaqAtaq313
03-18-2012 09:55 PM
kosstick
09-12-2011 12:18 PM
Gobbler Man
General Tech Questions
03-12-2010 08:00 PM
Quick Reply: 08 G37S slow shifting, 5AT all gears
