G37 crank position sensor issues
I know it's been a while but I'm now going thru the forum with the same problem. I measured the voltages coming out from the ckp sensor connector and I am also getting 5V on pin 1, GND on pin 2 and 5V on pin 3. Did you ever figured out why you had 5V on 2 out of the 3 pins ?
Once the tooth moves away, the output switches to ~5v.
cdnradio
01-09-2021 11:26 AM
jaimeandres21
02-10-2011 11:01 PM
G37RacerX
01-28-2009 08:40 PM
