HELP!!! P1148 & P0031 codes
Old 11-15-2018 | 04:56 PM
vicman521's Avatar
vicman521
Hey Guys,
I'm new here but I have an issue that's been driving me crazy.
I have a 09 G37x sedan
First, a few months back I had the P2A00 light come on.
I replaced the sensor twice, when the light kept coming on i figured out that my passenger side cat had a crack.
So I replaced both cats. 2 months later my light comes on again with codes P1148 & P0031.
- I checked the fuse and the fuse is good.
- I checked for leaks and can't find anything
Every time I reset the code it comes right back on as soon as I turn on the car.
Anyone else ever have this issue?
What was causing it?
Any ideas?
Thanks everyone!
Old 11-15-2018 | 10:01 PM
slartibartfast's Avatar
slartibartfast
Googling the codes makes think your passenger-side O2 sensor is the problem. It either has an electrical issue or the heater is malfunctioning.
Old 11-16-2018 | 08:59 AM
NealP's Avatar
NealP
When I was getting a P2A00 it ended up being an exhaust leak between the cat and manifold. I brought it to an exhaust shop to remove the cats, clean up the flanges, replace the gaskets, and throw in some RTV sealant. No more CEL a few hundred miles later *knock on wood*. Not sure about the other codes. I'd suggest finding a shop that's willing to check for leaks or you can do it yourself. Mine used the stethoscope method.
Old 11-16-2018 | 02:03 PM
vicman521's Avatar
vicman521
I was able to solve P2A00 when I replaced the cats
Now these 2 codes have come up and I'm stuck
From searching I do see that this is a common problem with G37s
But I don't see any posts with people stating what fixed it
If it was an electrical problem what exactly was the cause?
Old 11-16-2018 | 02:05 PM
vicman521's Avatar
vicman521
Thank you!
I'm leaning towards it's an electrical issue because when I reset the codes the light comes right back on.
But I'm just not sure of where to start
Old 11-16-2018 | 04:37 PM
slartibartfast
As I wrote, look at replacing the passenger side O2 sensor. The ECU can't get proper feedback that the sensor heater is working.
kickin_it
02-21-2022 04:47 PM
NeoNz
05-11-2019 10:30 PM
ImportPartsPro
Brakes/Suspension
202
09-02-2015 12:34 PM
akuma_83
06-05-2013 04:43 PM
OMG35S
06-21-2011 04:47 PM
Quick Reply: HELP!!! P1148 & P0031 codes
