Idler pulley came off while driving
Old 03-05-2020, 07:45 PM
antirice
antirice's Avatar
I would say replace them pulleys around 80k as a safety measure. Especially if you start hearing whiny noise from that area.
Old 04-25-2020, 01:49 PM
Alex Peña
Alex Peña's Avatar
What if bolt came off and couldn’t find it. Bought the pulley but it didn’t come with the bold, I went back and they said they didn’t sell them. Where can I get one ?
Old 04-25-2020, 03:00 PM
iCrap
iCrap's Avatar
Nissan or Infiniti dealer should have them. Or just check the FSM, go to advance auto and find the same type of bolt.
Old 04-25-2020, 04:28 PM
ILM-NC G37S
ILM-NC G37S's Avatar
Received 1,336 Likes on 1,082 Posts
If you bought the idler pulley new from Nissan/ Infiniti, a new bolt should have been included.
Best advice would be to remove the bolt from the other idler pulley and take it to a auto parts store and see if they can match it up exactly.
Old 10-02-2021, 05:54 PM
G_MENTED
G_MENTED's Avatar
Originally Posted by antirice
I have been noticing whistle/howling wind noise coming from the pulleys area for the last 2 days. Didn't think too much of it, figured it's probably the belt tensioner or one of the pulley, I'll just take it in maybe during the weekend to have a look.
Coming home tonight I heard a loud squeak, lost power steering and battery light went on. The Brake warning light also came on (anybody know why?). Luckily I wasn't that far away from home. Drove the car back home without power steering. This is the first time I've ever driven a car without power steering, so it was quiet an experience.
Pop the hood after I got home, notice the belt is quite lose. The belt itself didn't look damaged. Shine a flashlight down and there is it, the idler pulley resting peacefully on undercarriage cover.
FYI it's the #7 pulley in the diagram below:
Dude! Same thing happened to me. Thanks goodness I was close to home when it happened. Heard loud grinding noise when I accelerate and then the steering wheel got stiff, also saw the battery light start to flash. Couldn’t figure out visually what the problem was because belt was fine, no power steering fluid leaks, car was fine when I put it in gear, and it idled with no issue. Decided to check the next morning because I just spent 2.5 hours commuting home from the city. Started the car the next morning and saw the belt had slipped off and the pulley was found on the undercarriage cover too. Same #7. Thought it was the power steering pump at first. Got quotes for $190-300 for the idler pulley. I have 217k miles on my G37S.
blkceaser
11-12-2019 09:06 AM
Murkr
General Tech Questions
11-12-2018 09:52 AM
DevilsG37s
12-01-2015 12:17 PM
jmurbas
20
01-20-2015 11:24 AM
Quick Reply: Idler pulley came off while driving
