Auto Shifter issues
Old 12-19-2017 | 08:30 AM
Whiskeyriver's Avatar
Whiskeyriver
Auto Shifter issues
Hi guys so been searching and can't find an answer, I have a 13 g37 7at and I was vinyl wrapping some trim pieces. Long story short something broke when I was putting the shift **** back on. Its almost like the pin doesn't have enough power to push out the button on the shifter so with the shift **** on it wont lock into park and the button stays in. If I remove the shift **** it works fine the white pin moves up like its suppose to and locks into place in park. With the shift **** on I can move the shifter in and out of park without the button. Was going to go ahead and order a used shift **** off ebay but wanted to see if I should be looking at the shift assembly instead. Any help would be great. Thanks
Old 12-19-2017 | 08:29 PM
ethan10502's Avatar
ethan10502
Have you tried looking at the FSM under Transaxle and Transmission section? It has an explanation and diagram of the shifter assembly.
Old 12-20-2017 | 04:13 PM
Whiskeyriver
Yea I looked through the fsm a couple times and couldnt find an obvious solution. Wanted to see if anyone else has had this problem and if for them it was a problem with the button or the shifter assembly
4DRZ
03-13-2016 06:59 PM
foxktm90
06-24-2014 03:33 AM
LAG37
04-08-2008 02:57 PM
dalmond
General Tech Questions
01-24-2008 11:24 PM
Quick Reply: Auto Shifter issues
