370GT acceleration lag, bogging down.
Old 09-14-2017 | 04:57 AM
Nismo370's Avatar
Nismo370
Hi guys! I am new here.
I am now officially a proud owner of a 370gt 5 spd auto. Although the car comes with some serious issues.
The issues I am experiencing
- Throttle response is delayed, feels laggy.
- Manual mode feels like there is a 3 seconds delay between gears
- Sometimes the car pulls really hard, and other times the car feels like it wont accelerate hard, as if the engine is straining?
Is this a common issue with the 370gt guys? It makes it really hard to enjoy this car due to these issues
Any help would be much appreciated.
Old 09-14-2017 | 12:11 PM
jpowersjr2's Avatar
jpowersjr2
Do some research on here for a grounding kit. A lot of owners here have had great results from adding one to help improve the laggy auto transmission.
Sometimes a simple ECU reset helps as well.
How many miles on it? Spark plugs are supposed to be changed out at I think 105k miles. Another thing would be to clean out your throttle bodies.
Old 09-14-2017 | 02:06 PM
Patton6964's Avatar
Patton6964
I agree with Jpowers. I bought an 08 5spd auto and had the same issue when I first had it. Cleaned the throttle bodies and added the grounding kit. Shifts are super smooth now, I do still have lag down shifting from 4th to 3rd when I'm looking to get more power quickly though.
jpowersjr2 (09-14-2017)
Old 09-20-2017 | 11:50 AM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
If you have an 08 5 sp and your 4 - 3 delay issue is in manual mode , then press the gas first before downshifting from 4 to 3. for some reason when you downshift then hit the gas in that gear, the computer gets confused for a second.
@nismo370, Is that the delay you are talking about as well?
Old 09-20-2017 | 12:25 PM
Blade Runner's Avatar
Blade Runner
Also check the throttle bodies. Mine went bad and symptoms for me was terrible acceleration.
Old 09-21-2017 | 09:38 AM
supreme's Avatar
supreme
+1 for an ECU reset.
Also clean throttle bodies, and even run seafoam depending on your car mileage.
