Heater hose replacement: Cost? Coupler fix?
I just went through this process, losing all the coolant because of a disintegrated coupler. The replacement part that I used was DORMAN 56430 (Heater Hose Connector). It is available from O'Reilly (it is steel not aluminum). So far it works well. No leaks. As somebody mentioned before the most difficult part was to remove the old plastic coupler without getting parts of it inside the hoses - I had to remove the coupler piece by piece - it was breaking at the touch of pliers.
Why Infinity did not recall this thing or at least does not replace it during routine service is beyond me. For $10 worth of part, there is a risk of premature failure of the engine...
The following 2 users liked this post by QuinnDEskimo:
krazyfiend (11-24-2019),
MuffinButton (04-13-2020)
I'm having the same issue. I know it's likely the coupling and not the hoses that are leaking, but I figure I may as well replace the hoses too. If I wanted to replace with silicone hoses, is this what I'm looking for? https://www.z1motorsports.com/z1-sil...et-p-5202.html
Thanks!
Thanks!
While you are at it, get the part in the link below. The plastic coupler is prone to fail at any time, which is most likely the cause of your problem. I just replaced the coupler on mine and caught it right on time.
https://www.z1motorsports.com/coolin...se-p-9367.html
You can use this product as well, to save money. It is just as good and serves the same purpose, which is the one I purchased for my car and there are no leaks. So, you have two options to use.
https://www.summitracing.com/parts/rnb-56430
This is the coupler that I used for my car. https://www.summitracing.com/parts/rnb-56430
I provided two options for those who may prefer one product over the one product. Either way, one will not have to worry about that plastic coupler failing anymore.
This is the one that connects to the fire wall.
https://parts.infinitiusa.com/p/Infi...401-JK20A.html
This is the hose that connects to the lower rear part of the engine.
https://parts.infinitiusa.com/p/Infi...400-JK200.html
I just had failure of same connection on highway at midnite-car went into limp mode but got off road and found broken plastic connector-I appreciate help on parts and hopefully should get me back on road-by the way I have a 2010 g37 with 204K miles-going strong otherwise though may be time for coolant, spark pl;ug, hose maintenance on top of routine oil /filter changes which is about all I have ever done to this daily driver !
Mahalo
thank for the part number - this just happened to me & see that 3/4 & 3/4 fitting on both sides is good! Good looking out & all these threads help
I just had my 09 G37 (only 70K miles!) serviced including replacing coolant, which I normally would do myself. One week later this little coupling split in half. Damn. Gates 19625 hose is $8.79 on Amazon, and Gates (edit) 19705 is $5.83 19796 is $6.47. I ordered the Dornan coupling from O'Reilly and will get the tension clamps at the dealer I guess. I bought a couple of long needle nose at Harbor Freight but in the end I got the clamp off the firewall side with a cheapo mini needle nose vice grip. Once clamped I could work on twisting the hose off. I'm not looking forward to the more inaccessible engine side hose tomorrow, but I will endeavor to persevere.
I just had my 09 G37 (only 70K miles!) serviced including replacing coolant, which I normally would do myself. One week later this little coupling split in half. Damn. Gates 19625 hose is $8.79 on Amazon, and Gates 19705 is $5.83. They look correct. I ordered the Dornan coupling from O'Reilly and will get the tension clamps at the dealer I guess. I bought a couple of long needle nose at Harbor Freight but in the end I got the clamp off the firewall side with a cheapo mini needle nose vice grip. Once clamped I could work on twisting the hose off. I'm not looking forward to the more inaccessible engine side hose tomorrow, but I will endeavor to persevere.
I bought a flexible hose clamp remover but the wings broke off and had to resort to using a dremel with and extension flexible hose, mirror, and cut off wheel to remove the hose clamp. Alot of scraped knucles and cursing but finally came off. I managed to use hose clamps with socket set to get new hoses on with metal coupler. Back on the road with no problems.
Just changed my heater hose connector- it was mos def PITA
only pulled hose from firewall off
bought metal connector 3/4 inch for $4.99 at car quest
plastic connector piece wouldn’t come out & when I finally got it lose it went back inside of the hose
didn't want to pull hose of engine block - that clamp was hard to see & looked like a headache trying to get off & back on
since coolant was drained - got the dyson vacuum & sucked out all the small pieces in the hose with the vacuum
worked like a champ
used hose clamps to finish & saved 140 shop wanted to charge
worked like a champ
#29
Man this job is a pita seems like some of the spring clamps are a size too small on mine making alot worse had to cut most of my hoses off driver side hoses are so cramped the lower drivers side needed a long pick and hook hose remover to get off then I trimmed the z1 hose like 1/4inch because I couldn't get it on the passenger side engine one I was able to get off with a long 45 degree needle nose I bought a spring clamp tool but its useless with these undersized clamps probably just going to use wormdrives on all of them even though I don't like them.
I was also wondering why they used a coupler is it supposed to make installation easier somehow?
Either way plan on buying some extra tools or find a friend with very tiny hands and long arms
#30
So...I recently did this job and have a couple of suggestions. First though thanks to others here for the info to get me started.
To start, this job can be done without replacing radiator hoses. This saves the hell of trying to get them off the block and firewall. I only figured this out after breaking the tab on the spring clamp on the block and deciding not to take that house off.
Get 2 needle nose pliers. I'd suggest one long and one short. If you have a 90 degree that is ideal. Take the clamps off the connector. Grab either hose with the long ones and pinch it closed behind the connector. Use the other pair to crush the part of the hose that holds the connector. It will break easily into pieces and just pull them out with pliers. The key is to keep the hose pinched so no pieces fall into the hose.
When you buy the new connector also buy new spring clamps...I actually got those from infiniti. They are held open and VERY easy to get on. Just squeeze once in position. And try not to use screw clamps. They do but provide even pressure and have a nasty tendency to leak.
Also use a rubber safe lubricant on the connector and it will go into the hoses easily.
This saves you from experiencing the hell of trying to get those hoses off. Mine were perfect at 110k miles.
