I smell your testpipes lmfao
Old 03-10-2017 | 06:57 PM
Kris9884's Avatar
Kris9884
Yeah, if you're going to swap out for anything other than OEM cats, just get the resonated test pipes. The performance gains are very similar between the HFC's and RTP's but the price of test pipes are a fraction of HFC's. Plus, getting test pipes back off are far easier than cats over and over.
Old 03-10-2017 | 07:25 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
If you want a tune go see Seb at Specialty Z in Chatsworth you won't be disappointed!
slowguy27 (03-11-2017)
Old 03-10-2017 | 08:02 PM
joeg37x's Avatar
joeg37x
Saul Nismo knights he does a very good job on tuning.
Old 03-11-2017 | 07:06 AM
slowguy27's Avatar
slowguy27
Thank you fellas, defiantly appreciate all the input. I'll post some pics when parts come in.
Old 03-11-2017 | 10:31 AM
If you are doing the install here's a thread that should help & be sure to use the 50-50 Acetone/ATF mix to help w/ breaking the bolts free~
https://www.myg37.com/forums/g37-sed...y-be-atch.html
slowguy27 (03-13-2017)
Old 03-11-2017 | 12:23 PM
WillCo1's Avatar
WillCo1
I second this.
I wouldn't even attempt to remove factory OEM cats without first soaking the bolts for at least a couple hours in the 50/50 mix.
PB Blaster etc. is garbage compared to the 50/50 mix.
Thanks again blnewt for this pro-tip.
blnewt (03-11-2017)
