G37 coupe plenum vacuum leak at center screw
Old 05-25-2019 | 10:37 PM
xmajd92's Avatar
xmajd92
I've seen that. The Motorvate guy gives some pretty good insight into our cars.
Old 05-25-2019 | 10:47 PM
Atowsley's Avatar
Atowsley
Good to know! Thanks
Old 05-26-2019 | 12:24 AM
Gage Sarnes's Avatar
Gage Sarnes
Originally Posted by SonicVQ
Thank you. I will throw some locktight on it tomorrow!
Old 07-15-2019 | 02:51 AM
Aymenoo's Avatar
Aymenoo
I’ve had the same issue after installing Stillen gen 3 intakes, decided not to put the cover back on, forgot to put the screw on and car was running rough and a loud hissing noise was there, screwed a screw in there, I’m sure I tightened it (obviously not knowing it could crack) and it went back to normal, drove the car for a few days and it starting misfiring lightly after coming off the highway. The misfire has gotten worse, so I’m going to change sparks, coils, o2 sensors, a new catalyst ( mine got torn apart because of the misfires I believe ), clean MAF and throttle body. Hopefully that’ll fix it, if it doesn’t then I’ll be sure it’s coming from the plenum and I can use that as an exuse to switch to Z1 ported plenum 😍
I might need a tune because I have the Stillen intakes and a full Magnaflow Catback. ( This could also fix)
Will update this post when I get the new parts in!
Old 07-15-2019 | 05:19 AM
Surfnazi's Avatar
Surfnazi
You could use liquid steel epoxy or jb weld
Old 07-15-2019 | 11:25 AM
slartibartfast's Avatar
slartibartfast
Start with the throttle bodies and MAFs. Don't throw money at it until you've done the free stuff first.
Old 07-16-2019 | 07:21 PM
Black_Vegas's Avatar
Black_Vegas
Another inexperienced lube tech strikes again. Instead of hand torquing the bolt down, they used the good ol’ trusty 3/8in impact gun and gave it 3 chuga chuga’s. I see it all the time at MB.
Old 04-03-2022 | 12:57 AM
Avery Madrigal's Avatar
Avery Madrigal
Originally Posted by dom_sinserious
Hello Guys,
I am new to this forum, and this is my first post. I am glad to know everyone, and receive help from the Infiniti gurus.
My car is the 2013 infiniti g37x coupe. Today I removed the engine cover to clean the plenum.
I am pretty sure everyone know that there are 5 screws to hold the engine cover down. The moment I removed the center screw, suddenly I heard the hissing noise came out from that screw hole, and when I touched it, it seems like a vacuum leak, and idle rpm dropped to 500rpm.
I wonder if it is normal that Nissan/infiniti designed their plenum with center screw hole created vacuum?
to note that the moment I put the screw back in, no more hissing noise, and also the idle rpm went back to normal.
I hope I can get help since I tried to search on the internet and found no luck thus far.
Thank you in advance
(the attached photo is just a random Infiniti/Nissan plenum I found on the web, and put a red arrow in to show everyone where the screw hole located)
center screw hole (red arrow pointed at)
what is the size of that bolt ? I’m missing that
Old 09-26-2022 | 09:13 AM
gomogloVQ's Avatar
gomogloVQ
Originally Posted by xmajd92
I removed my plenum cover. Put the screw back in. No big deal.
what are the specs for the screw lol
