3-4 gears cause engine to rev when shifting up
I posted a thread late summer of this year about how my engine was revving up whenever I was shifting from 3rd to 4th. I was told that there was a TSB for the issue but unfortunately the nearest dealership to me is about 2 hours away so I never made a trip to get it done.
Since then this issue has become worse and now affects 3 - 4 gears instead of just 1. I'm really hoping you guys can shed some light on this so I know what I need to do.
It seems like this only happens when I'm not accelerating very fast. If I'm just gradually getting up to speed that's when I notice it. If I hit the pedal hard then it won't rev up but the 3rd-4th gear change is a little harsh. 3rd - 4th is now revving up almost 1,000 RPM before shifting and it's annoyingly noticeable.
Any ideas what this could be? I'm going to take it to the dealership around the end of this month probably but it would be nice if I could get some ideas of what it could be here first.
It's also worth noting that is a 2009 g37x with about 70,000 miles on it with the automatic transmission.
you gotta give the vvel time.. so practice on not pushing the clutch and leaving it in the resting position till you have fully let go of the gas..
a light flywheel should help for this since the engine wont have momentum to keep spinning.
I would first reset the ECU so you can force the tranny to relearn. During the relearn process see if the issue arises or subsides and move from there.
The transmission can become wacky sometimes and a reset seems to help for some things.
Same here.
I have the same issue with mine. 2010 with about 88000 miles. It is always most noticeable when slowly accelerating. Ended up doing a transmission flush and fill at the local dealer which didn't do anything. I'm wondering if this is somewhat normal? It's been like that ever since I bought the car. I hope it's not a by product of transmission failure! Would love to know if anyone else has been experiencing this.
