If your car clicks over bumps at low speed sway bar endlinks are worn easy 20 mins swap once you remove wheel. Motor mounts are filled with hydraulic fluid look for cracks
I think my inner tie rods are bad. The rack and pinion boot has grease leaking and it’s not the oem clip, it’s just secured by loose zip ties so I ordered new rack and pinion bellows, inner and outer moog tie rod ends. They should show up Tuesday hopefully they get rid of the clunks. The wheel pops when I rock it back and forth after I lift it off the ground.
