Help g37x coupe front axle
Hi tscani,
Not sure if this will help but here's a link to the Manuel for FSU. I'll look at the rest and see if there's another part that lists part numbers. Why do you ask if I may ask?
https://www.dropbox.com/s/5l1i3zln481o5bi/FSU.pdf?dl=0
tscani (07-28-2016)
If you have replaced CVs before they are not that hard. The drivers side is a little interesting because you have to unbolt it near the oil pan, but I found coming at it from in front made it easy. Passenger side is straight forward. Good luck!
I leaned the G35X CVs work as well, FYI. When I ordered my replacements on had an ABS ring, it didn't effect anything or make a difference. The other didn't. I think I got them online for close too $70 each if I recall.
tscani (07-28-2016)
Pimpani
04-20-2016 01:20 PM
