g37s vs G37 IPL rear differential
do you guys know if there is a difference between the 09 g37s rear differential and the IPL REAR? I need to replace mine and there is one close by I want to pick up but want to make sure it will work before I pull the trigger because I see on driveshaftshop.com the upgrades say "except IPL" so I'm worried now there is a difference
The differentials are compatible sedan, coupe etc. I can put a 08 g37 S vlsd in my 7 speed auto sedan and be okay. I'm pretty sure the differential on the ipl is the same as the diff in the g37s coupe. I think compatibility will be fine
slartibartfast (06-01-2016)
GFTW
05-05-2016 11:29 PM
