So yesterday I had some free time, so I went and removed all the plugs and cleand them thoroughly with chemicals along with the throttle bodies. And then fired the plugs up with a torch. They're now 80% near new. I had the chance to take some before pics but not after cleaning because it was very late and the phone died on me
Result: I say 85% improvement. Rarely to notice any misfiring or shaking. I wanted to replace all the plugs with new ones but didn't have them in hand at the time and I had to do something in my off days. I will be changing them soon and also inspect the coils.
Pics:
Tell me what you think for only three months plugs!
Fuel trim screenshot:
Here is a test report after all that:
Test report:
MID:$01 TID:$83
- O2 Bank 1 Sensor 1
Max: 65.535V Min: 0.4V
Test result value: 2.19V
PASS
MID:$01 TID:$84
Max: 4.399V Min: 0V
PASS
MID:$01 TID:$85
Max: 2.149V Min: 0V
Test result value: 2.07V
PASS
MID:$01 TID:$86
Max: 65.535V Min: 2.25V
Test result value: 4.11V
PASS
MID:$01 TID:$87
Max: 65.535 Min: 0.3
Test result value: 0.42
PASS
MID:$01 TID:$88
Test result value: 0.456
PASS
MID:$01 TID:$89
Max: 0.449 Min: -32.768
Test result value: -0.138
PASS
MID:$02 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 0.17V Min: 0V
Test result value: 0.17V
PASS
MID:$02 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 2.55V Min: 0.7V
Test result value: 0.7V
PASS
MID:$02 TID:$80
Max: 1.19V Min: 0V
Test result value: 0.69V
PASS
MID:$02 TID:$81
Max: 2.55V Min: 0.48V
Test result value: 0.5V
PASS
MID:$02 TID:$82
Max: 3.9S Min: 0S
Test result value: 3.1S
PASS
MID:$05 TID:$83
- O2 Bank 2 Sensor 1
Test result value: 2.12V
PASS
MID:$05 TID:$84
Max: 4.399V Min: 0V
PASS
MID:$05 TID:$85
Max: 2.149V Min: 0V
Test result value: 2.145V
PASS
MID:$05 TID:$86
Test result value: 4.115V
PASS
MID:$05 TID:$87
Test result value: 0.548
PASS
MID:$05 TID:$88
Test result value: 0.442
PASS
MID:$05 TID:$89
Test result value: -0.062
PASS
MID:$06 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 2
Max: 0.17V Min: 0V
PASS
MID:$06 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 2
PASS
MID:$06 TID:$80
Max: 1.19V Min: 0V
Test result value: 0.62V
PASS
MID:$06 TID:$81
Test result value: 0.48V
PASS
MID:$06 TID:$82
Max: 3.9S Min: 0S
Test result value: 0.4S
PASS
MID:$21 TID:$80
- Catalyst Monitor Bank 1
Max: 255 Min: 10
Test result value: 6
FAIL
MID:$21 TID:$82
Test incomplete or dependant test failed
MID:$22 TID:$80
- Catalyst Monitor Bank 2
Max: 255 Min: 10
FAIL
MID:$22 TID:$82
MID:$35 TID:$80
Max: 13° Min: -13°
Test result value: 2°
PASS
MID:$35 TID:$82
Max: 13° Min: -13°
Test result value: -0.5°
PASS
MID:$35 TID:$84
Max: 499ms Min: 0ms
Test result value: 122ms
PASS
MID:$35 TID:$85
Max: 10,779ms Min: 0ms
Test result value: 10ms
PASS
MID:$36 TID:$80
Max: 13° Min: -13°
Test result value: 4.5°
PASS
MID:$36 TID:$82
Max: 13° Min: -13°
Test result value: 0.5°
PASS
MID:$36 TID:$84
Max: 499ms Min: 0ms
Test result value: 119ms
PASS
MID:$36 TID:$85
Max: 2,379ms Min: 0ms
Test result value: 20ms
PASS
MID:$3c TID:$81
- EVAP Monitor (0.040")
Max: 32.767kPa Min: 0.43kPa
Test result value: 32.767kPa
PASS
MID:$3c TID:$82
Max: 32.767kPa Min: 0.1kPa
PASS
MID:$3d TID:$83
- EVAP Monitor (0.020")
Max: 655.34998V Min: 0.02V
Test result value: 0.06V
PASS
MID:$41 TID:$81
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 4.779V Min: 0.39V
Test result value: 1.11V
PASS
MID:$42 TID:$80
- O2 Heater Monitor Bank 1 - Sensor 2
Max: 4.71V Min: 0.24V
Test result value: 1.58V
PASS
MID:$45 TID:$81
- O2 Heater Monitor Bank 2 - Sensor 1
Test result value: 1.085V
PASS
MID:$46 TID:$80
- O2 Heater Monitor Bank 2 - Sensor 2
Test result value: 1.5V
PASS
MID:$81 TID:$80
- Fuel System Monitor Bank 1
Max: 130.98999% Min: 77.00999%
Test result value: 93.68999%
PASS
MID:$81 TID:$81
MID:$82 TID:$80
- Fuel System Monitor Bank 2
Test result value: 94.71%
PASS
MID:$82 TID:$81
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count Min: 0Count
Test result value: 1Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
Test result value: 0Count
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
Test result value: 3Count
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
MID:$a6 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 5 Data
Test result value: 2Count
PASS
MID:$a6 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 5 Data
PASS
MID:$a7 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 6 Data
PASS
MID:$a7 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 6 Data
PASS
With AC on ignition timing advances to keep engine torque enough to compensate for parasitic loss. Anyways, leaky cam cover, oil on coils or plug threads?
Nope, there is no leak on cover or any other part on the engine bay. Couple of times the engine oil cooler sandwitch plate leaked but I tightened it up and no leaking since.
Ok just skimmed through your scan results.Bad O2? Running rich when that happens.plugs look a bit coated . when AC on timing burns more fuel si maybe why it runs smoother.
Bad O2 due to the test pipes. Everytime I reset the ECU, it takes sometime for the CEL to come back again. Weird that it took two days with over 500 mi driving now without throughing the codes. I think the Upstream and downstream O2 sensors are also coated like the plugs or even worse for them to not detect the test pipes quickly.
If you read post #21, I mentioned that I used STP cleaner. Maybe using that cleaner through the brake booster was a bad idea anyway and got the plugs along with the O2 sensors to go bad and making them get bad reading of the burnt mixture hence the off fueling and misfiring.
Just guessing here.
Originally Posted by Rr1982
Does is smooth out with AC off and high beams on?
I'm not sure. I will test that tomorrow morning and report back.
Okay once again forgive me I haven't read the whole thread do you have live bands are you running race gas
It's ok for not reading the whole thread. Your help is appreciated.
What do you mean by live band?
No haven't run a race gas before. Only some homemade toluene mix that I did like 7 months ago and haven't had any problem when I did it. It was only for two gals just for the sake of testing the timing adv.
Okay I read your scan reports I didn't see anything about Cylinder 6 misfire maybe I missed it I do however see that it looks like your O2 sensors might be dirty or failing on both Banks. Why are you getting all this dirt in your intake tubes and why did you shoot at STP into a vacuum line
