What's the best fluids for differentials and transfer case????
Ok guys, this forum has been great helping this Noobie work and get some great info on my build. But the time has come for my G37X to get her differentials done and transfer case oil swapped as well. What do you guys think is the best safe aftermarket brands for this ? Or should I just buy all Nissan supplied fluids???? Thank you all!!!
OEM is perfectly fine. You may get a ton of different opinions on what everyone prefers. The truth is that any of them are more than sufficient and it's just about people's personal preference. I don't believe that anyone has posted a used oil analysis for those which is the only way to see anything.
Just about any compatible brand will be better than the dirty fluids in there now. If you're not comfortable picking a specific brand stick with OEM/Nissan fluids. I used Amsoil for the transfer case and Mobil 1 for both difs. Be careful breaking the fill plug loose on the front dif. I had to use a breaker bar and ended up messing up my oil pressure sensor. It was easy to replace tho.
Thank you everybody for their inputs l think to play it safe all around I'm going to stick to OE from Nissan and keep my piece of mind. Gotta keep yoshi tip top !!!
warpeacelove
04-20-2016 05:45 PM
beto4632
04-14-2016 07:28 PM
04-07-2016 08:51 AM
