G37x sedan cv axle help
Old 04-05-2016, 09:21 AM
Gthangftw
Gthangftw's Avatar
What's up everyone so my axle started making a clicking noise. front passenger, the boot was torn for a while so it was time to replace the axle. I got everything off caliper rotor coilovers and got the axle freed from the Hub can anyone give me advice or tell me how to remove the axle from the diff I tried prying it out and wouldn't move advice ?
Old 04-05-2016, 09:40 AM
jfisher
jfisher's Avatar
Should be nearly identical:
DIY: AWD front CV half shaft removal / CV boot change - G35Driver
Old 04-05-2016, 10:04 AM
si_driver
si_driver's Avatar
should be the same as jfisher pointed out.
Old 04-05-2016, 10:09 AM
G37Xtreme
G37Xtreme's Avatar
Originally Posted by jfisher
Looks like OP is at the pry step of this DIY.
Were you able to get a tool in there like in the photo? Was it just seized in there? Maybe try again with a wider pry tool which should give extra leverage. Or perhaps impact to the pry tool, but use caution so you don't damage the front diff.
Old 04-05-2016, 12:28 PM
Gthangftw
Gthangftw's Avatar
I'll give it another try see what happens thank you any other advice is appreciated
Old 04-05-2016, 06:55 PM
Gthangftw
Gthangftw's Avatar
So I'm having issues can anyone help me out on trying to remove this
As u can see i tried to pry it out with a friend holding the base of the axle and end up giving loose and came out the socket
This happend so how can I get this off
Old 04-05-2016, 08:51 PM
Gthangftw
Gthangftw's Avatar
Do both axles need to be off the ground ?? Only one side is jacked and the other isn't
Old 04-05-2016, 09:27 PM
SonicVQ
SonicVQ's Avatar
Use a larger pry bar or long screw driver in the same spot and slowly increase force until it pops out.
It shouldn't make any difference that only one side is jacked up, however that doesn't give you much room to work..
Oh My G 523
04-06-2016 03:46 PM
JUMBO PALACE
04-05-2016 10:01 AM
Jbunz
04-04-2016 08:20 PM
lashk
04-04-2016 05:13 PM
Quick Reply: G37x sedan cv axle help
