Performance bolt ons- What to do next?
Just an FYI this is my first post I just joined like a month ago. Anyways, I have an 09 g37x coupe with almost every bolt on available. I'm making pretty good power now for an NA but like always, I want more. My list of mods now is test pipes, y pipe, cat-back, short ram intakes, m370 upper intake manifold, lightweight under drive crank and alternator pulleys, and an uprev tune. It's crazy fast compared to what it was before obviously but I always want more. Problem is I'm not sure what to do next so I wanted to get some opinions. I was thinking maybe 60 or 63mm throttle bodies and bigger intake tubes, lower intake manifold, or new gearing (which I'm not sure is possible on AWD). I also sometimes pull my AWD fuse and go rwd when racing, it makes a significant difference. I'm currently running 20" wheels that are heavy as **** and I'm working on getting a lighter set now, which I know is gonna make a huge difference. Anyways, give me your opinion on what I should do next.
Ginger ninja
What's your budget?
If you've got hella extra cash I vote for some fast intentions Long tube headers baby!! I put them on my vert and omg the sound and the gains are nyioce!!
If your budget isn't $1400 strong then I vote for a Takeda long tube CAI. This was my first mod and even after 15-20 mods later it's still one of my favorites. Improves the sound and the power instantly and doesn't require much work or time to install.
Let me know what you think! Btw nice work on tour bolt ons so far. Impressive.
Mikekg37x (01-28-2016)
What's your budget?
my buddy is a mechanic and sent me an entire google doc with everything I would need to do a 100 shot on my car and ive thought about it but I just don't know how reliable the motor is gonna be after a few months with a nitrous setup on it. anyone have an idea on what the maintenance is like on a nitrous setup and what the long term effects on the car are? and yea im thinkin LTH are gonna be next most likely
NeverBoneStock did it from back in 2011 and had up until late 2015 because he's going boost. he had a nitrous express kit. another easy kit is the Zex kit.
NeverBoneStock build thread: https://www.myg37.com/forums/engine-...us-set-up.html
Nitrous Express kit: NISSAN / INFINITI DUAL NOZZLE (35-150HP) W/ 10LB BOTTLE
Zex kit: ZEX? '07-'09 Nissan 350Z Nitrous System
Mikekg37x (01-29-2016)
I was on that "not sure" about headers, pulled the trigger got retuned and pick up power every where. My thread from this past weekend is here. I would go headers and save $$$ for cams. I looking at those next
Carbor Fiber Driveshaft.
Contact import parts pro for a quote on the driveshaft. U can contact pst driveshafts directly also. In a automatic G. I'd quicker save for a level 10 transmission upgrade. Headers would be perfect for a n/a build. There's also the pulley upgrades. Grounding kit. Ported lower intake. Get them all!
