08 G37s Cranks, Won't Start
Hey fellas, was looking for some help. I recently ran into a completely out of the blue problem.
My 2008 g37S coupe (66,000km) was sitting for about 3 days and when i came to start it up in the morning it would turn over, but wouldn't start. It was driving perfect before, never had an issue.
I've changed the battery, was probably not needed but did anyways. Checked every single fuse, fuel pump is priming, haven't pulled a plug yet to check for fuel and spark but from what I've been reading it's not that.
I ran a OBD 2 scanner and got no codes. The I/M readiness test indicated O2 Sensor Monitor, Catalyst Monitor, and Evaporative System Monitors as not ready that's all.
It's looking like I will be sending it (towed) to Infiniti, but I wanted to brainstorm some possible problems and have any idea at least before I give it to them. Reason being I don't trust dealers at all.
Anyways, any ideas would be most appreciated. I'll update this thread if I find anything out and when it's fixed in case anyone else has the issue.
Thanks!
Thanks!
Okay, another dilemma. Checked spark and fuel both were good, and it started...
So I still don't know what was the issue, and now have a car, that runs, but I don't trust because I never resolved the issue...
I had a similar problem with my '08. It wouldn't start and since I couldn't find any issues with it, I changed the spark plugs. When I pulled out #3, I found that the porcelain had cracked on the plug. Replaced all 6 plugs and have not had a starting problem since. I may have accidently fixed something by removing the coils, but the only thing that I noticed that was bad was the plug.
Need 4 Speed
Wheel & Tires
19
08-16-2016 04:14 PM
02-16-2016 11:02 PM
si_driver
01-25-2016 11:02 AM
Zelf24
01-03-2016 12:59 PM
