Code po710, anyone dealt with this?
Hey guys, I got a service engine soon light, so I popped in the computer obd2 reader, and it came up with code PO710. It says it's either :
1. Actuator Sensor Power Supply
2. Fluid Temperature Sensor A
I'm guessing basically it's the transmission fluid temp sensor, and I don't want to take her to infiniti which will cost me 90$ to diagnose, and God knows how much to fix the sensors. Anyone have any experience or had success with this? Thanks a bunch
P0710: Transmission Fluid Temperature Sensor A Circuit
Three possible causes:
(1) A/T temp sensor failure
(2) A/T temp sensor circuit open
(3) A/T temp sensor circuit shorted.
Have you checked the fluid level and colour?
Has any other work been done on the car is the last while?
The A/T temp sensor can be accessed by removing the transmission pan, so if it has failed it is easy to access.
http://www.infinitig37.com/TSB/ITB13-019a.pdf
What year is your car? also, are you still under warranty? There is a TSB for 2013's that have the P0710 code....
When I lived in So Cal and had my M35, I had a recall procedure done at Southbay Infiniti but had Church's Auto Tuning flash my car back to stock since I didn't have the Uprev Cable, then I went back after the dealer was done. LOL, I'm currently looking to pick up a used Uprev Cable to do remote tuning on my G.
Good luck with the fix
How did things go?
I just pulled the same code today after my commute to work. I suspect it could've been caused by excessive manual use in the last few weeks or just transmission fluid check due. I will give an update.
Code No Longer Shows Up
All,
I took a break from manual shifting since seeing this code and it has never returned. I am getting close to the maintenance schedule recommended transmission fluid replacement. I think that this, combined with consecutive days of manual shifting, may have been responsible for the code. Will update if anything changes.
Dealer was giving free oil changes away. They didn't talk to me, but I saw online that they read po710 CEL was on about 8 months ago. Quoted $85 to do the po710 TSB procedure. Context - diagnosis of anything there costs $160 and syn oil change $125. Brakes stupid expensive; ~$1k per axel?! I've never brought it there for an oil change or brakes.
Spark plugs are $400, which may actually not be terrible if I could get them to use my parts and give credit for it.. Hmm.
Michael Moheban
19
01-19-2024 06:26 PM
01collinp
01-24-2020 12:23 PM
