6MT: Grinding 4th to 6th and 6th to 4th
Old 02-10-2016 | 09:56 PM
  #31
goredcar's Avatar
goredcar
Originally Posted by supreme
You need a tune/re-tune/better tune if running FI. Not sure how that will playout with the tranny warranty...
Not sure if I am getting you. The has been custom tuned, and data logged afterwards with real time changes to optimize the tune. Are you suggesting that they might not be willing to warranty because of FI?
Old 02-13-2016 | 11:38 AM
  #32
supreme's Avatar
supreme
Yes, I couldnt imagine warranty being honored with direct modification of the drivetrain.
Old 02-13-2016 | 01:28 PM
  #33
Epiphany's Avatar
Epiphany
I'd have to agree, I doubt you'd be getting any warranty coverage on the transmission now that you've supercharged the car.
Old 02-16-2016 | 03:45 PM
  #34
chilibowl's Avatar
chilibowl
Yup, drastically increased power could be the reason to the early failure of synchros.
All I will say is, you better hope the dealer you visit is "mod friendly".
On a brighter side, a used CD009 transmission isnt all that terribly expensive nowadays.
Old 02-16-2016 | 03:48 PM
  #35
chilibowl's Avatar
chilibowl
Originally Posted by evil-G-nius
I do...but its annoying. I don't always do it because I am just driving...I don't thinkg about it most times. I am usually on auto pilot
It sounds like you drive the usual mt rookie.
I can go from 6th to 2nd and the car doesnt make a peep, aside from a louder engine.
An experienced and proper manual transmission operator can go from 6th to 4th, 6th to 3rd, 5th to 2nd, or whatever is desired without ANY stress on any part of the transmission/driveline. I know so because I do it everyday.
Old 02-17-2016 | 11:40 AM
  #36
canucklehead's Avatar
canucklehead
^ OP must have gearbox issues. doubt it is operator error. anybody should be able to skip shifts - it is not a highly skilled practice.
i almost never shift sequentially (1-2-3-4-5-6). in anything but rapid acceleration i shift 1-3-5, 1-2-5, 1-4-6, 2-4-6, 2-5, etc, depending on road grades. occasionally i even do so without touching the clutch pedal by rev matching. it's an easy enough practice to do particularly in the lower gears 1-4. never heard a grind or balk from the gearbox.
Old 02-17-2016 | 12:42 PM
  #37
SonicVQ's Avatar
SonicVQ
goredcar: The first thing I would try is the proper Nissan HQ Multi 75W-85 manual transmission fluid. It has the proper friction characteristics for that exact tranny.
If that MTL is already in the tranny, then the syncros are worn and not spinning the mating gear up to proper speed. Time for a used or rebuilt tranny.
JUMBO PALACE
12-15-2015 02:11 PM
_GH0ST_
12-08-2015 11:22 AM
killingforpeace
12-07-2015 11:43 PM
andy_9k
12-07-2015 08:55 PM
Broken_2008_G37
12-07-2015 06:50 AM
Quick Reply: 6MT: Grinding 4th to 6th and 6th to 4th
