G37s takes a while to start
Old 11-21-2015, 07:59 PM
Glenn2008
Glenn2008's Avatar
Originally Posted by OfficialG
Is this all in one push of the button? Or do you mean you have to go through the sequence of pushing the push start button 3-4 times? If it's the latter, I just had the same issue. My clutch safety switch went bad and was replaced under warranty (2012 with 30k). It now starts first time no problem.
I just returned from a 3 day trip and had the same problem. I was pushing the start button 2 or 3 times to get the car to start. I discounted the battery because, if it doesn't start the first time, I don't believe that it will fire off the next time. I've had the start switch problem on a Honda Accord and what I did was spray the switch with an aerosol used on electrical circuits/connectors. I did it over two years ago and haven't had one issue with the car since. I read it somewhere on the internet and it worked for me. FYI: just sprayed the switch and worked the plunger a few times. Started the car 5 times w/o a problem. I'll probably buy a new switch on Monday and install.
Old 01-30-2016, 03:51 PM
Glenn2008
Glenn2008's Avatar
Update: I didn't buy a new switch, I just adjusted mine. Used a 14mm open end wrench, loosened the jam nut and screwed the threads on the switch in about a 1/2 turn and tightened the jam nut. No problems since.
ThebigJ
12-20-2015 09:19 AM
AMCDeac
10-21-2015 09:50 AM
GW330
10-16-2015 02:29 PM
Marcelinom
26
10-13-2015 07:49 PM
Camvill
10-11-2015 01:46 PM
Quick Reply: G37s takes a while to start
