rpms surge after 5500 rpm while in a curve --2nd gear-tire slip or differentia
While smoothly accelerating in a curve, I've very often gotten an rpm surge. (quickly up from 5500 to 6500). I can't quite tell if somehow I'm getting some odd throttle behavior where it decides (oh, ok, I guess you really want more throttle, and not the moderated one we were provided you before). Or, if I'm reaching the edge of traction of one of the rear tires, so there's some slip, rpm goes higher. If it were one of the rear tires losing traction, I would have thought I would have heard some squeal. Are there any unusual differential behaviors which could account for this? G37S 7AT. (traction control off --- private facility, not on public roads)
telcoman (11-15-2015)
As indicated in the title of the thread, 'in 2nd gear'. . And incase it wasn't clear: manual mode. no downshifting
Originally Posted by Thirty_Seven
You won't necessarily hear tires squealing, it's not as loud as it is in movies. Look for the SLIP indicator light on the dash if you have traction control on.
Yes, traction control had to be turned off as it would go into the 'I see what you did there' mode, and kill the throttle for what seemed like .5 sec or more --- awful for timing purposes. Guess I'm going to have to practice more to judge 'tire slipping'. Tough when you're trying to slowly increase speeds to gauge what you can and can't do.
Yeah if traction control was off everything points to you were just getting it more than you thought but you must have been barely slipping if you didn't notice at the wheel and have to counter steer at all. I just picked up a G and I've been putting question marks all over the pavement, but I'm really excited to take it on frozen lakes in the winter and learn it all although I'll need snow tires to do so.
