What spark plug is good for Infiniti g37
Old 03-22-2016 | 07:31 PM
hobbs's Avatar
hobbs
Off topic, but . . .
Originally Posted by Jsolo
^^Agreed! Unless you're an engineer and truly understand . . .
This also applies to grounding kits.
Old 03-23-2016 | 08:39 PM
xnick101's Avatar
xnick101
Originally Posted by Kris9884
I had the same question and searched everywhere and none of the manufacturers said they were pre-gapped. But if you search for a pre-gapped plug they all make sure to mention it so I'm going to go out on a limb and say no, you have to gap them to spec. Which is .044 with about .02 play room.
So finally got a good answer on this issue, called up my friend that works for Nissan and he told me laser iridium plugs use the same gap across pretty much every car. They double check the gap before installing it but they don't gap the plugs. So either one you buy will be fine.
Old 06-17-2016 | 01:44 PM
Rr1982's Avatar
Rr1982
Try opening the gap in an Iridium plug, you'll either break the electrode or dull the shape of it.
ECS (03-29-2020)
Lt8Che
12-31-2016 01:40 PM
Eddyj28
05-17-2016 08:59 AM
Wicked_limitz
03-15-2016 06:08 PM
Tanbag
11-01-2015 07:25 PM
sukhusukhu
10-15-2015 03:56 PM
Quick Reply: What spark plug is good for Infiniti g37
