turbo or super charger?
If he is up to it then it's obviously a better choice, but from reading his posts, I doubt he is willing to. The kit is very reliable as long as you don't try to mess with the design and have a good custom tune. Most of the popped motors I see are from people trying to upgrade the kit, run Stillen's tune, or have a terrible tuner. I can't really say much, since I've only had the kit for a year, but I've yet to have an issue.
Chances are if he wants to push more torque with a turbo setup, he will have to do Level Ten's complete transmission build, which will run over 4k alone.
Not necessarily. You can get the single turbo kit I installed for the same price as the Stillen and mine came with the oil cooler included and everything (minus tools) that you need to install it. I installed it myself in two weekends. I could easily do it in one but I took my time and also spent most of the second weekend doing mostly electrical/gauge work.
The beauty of a turbo kit is you can control the amount of power you want by changing the pressure in the WG.
does any one know how much the gtm turbo kit is?
what kind of tune do you recommend for the stillen kit, if stillen's tune is no good?
what is wrong with the standard stillen tune?
Gamma (GTM) turbo kits start at around 9k I believe. It's hard to suggest going to them because of their history. It's also impossible to say whether your engine/transmission can handle the torque, since everyone has a different experience. I've heard of people running GTM's 1.5 SC kit for multiple years and that runs on 50trq more or so.
The problem with the Stillen tune is that it is pretty much a generic OTS map that you flash onto your car. Every car is different, so you never know how your car will react to theirs. For custom tuning, you can go either Uprev or EcuTek. I initially had Uprev, but switched over to EcuTek because it's tuned off of speed density instead of the MAFs. This is pretty much where the Stillen kit is weak at (MAFs are in the wrong spot, so they can't properly monitor the intake temps).
ShuuraRG (11-13-2015)
Did you have to add anything else to go to speed density? My tuner was suggesting going to a Juke MAP sensor and tuning off of those readings.
jwick Build Thread - First BP - G37T in existence - Nissan 370Z Forum
I have over 400 ft-lbs before 4k rpms. There's a dyno chart in that build thread link but I'm not sure if it's may latest. I had it retuned when I swapped my Stillen exhaust for Fast Intentions.
Yeah, running Speed Density would be the savior for the Stillen kit. The intake is the reason why great tuners refuse to tune that kit. Unfortunately, EcuTek isn't available for 2008 ECU's, and the swap hasn't been figured out. So if you have a 2008, you're stuck with UpRev - just find a good tuner.
As far as the install differences, a lot of the TT kits require you to remove/lift the motor and do it on a lift, while the Stillen kit is mostly on the top of the engine bay. It can be installed with the car on the ground and the hood up. Also, if you're AT, I'm not sure what that does to your available options.
Lastly, throttle response. A supercharger doesn't show numbers the same way as a turbo car does, but it drives like a bigger motor. Same characteristics as it had before, just more everywhere. A turbo motor feels like you're throttling a turbo. Even if you minimize lag, you still find yourself throttling the spool characteristics of the turbo, not just throttling RPM. Don't know if this matters to you, and some people prefer this since the power comes on in a whoosh, but for road racing, a supercharger's predictable and instant throttle response is the way to go.
The major benefit to a turbo is the instant torque and the ability to control desired power by WG control. It does however take some getting used to if you aren't expecting that much torque basically in an instant in a turn.
#29
I actually walked away when he did this, but I'm assuming it was a direct swap because he did it pretty fast. The only thing i have is the stock one and the bag that the gtr ones came in. I could shoot an email over to him to confirm though.
#30
No worries. Just wondering. My tuner gets his Ecutek tuning software from Visconti anyway. If I have to go that way I'll get the same thing you do.
