Transfer case was leaking
At 39,000 I saw some fluid/oil leaking from the transfer case seal I think.
Took it to the dealer and they fix it.
Can I assume that in order to fix the seal and/or what ever was causing the leak, they would have needed to replace the fluid/oil as well ???
Yes, I had to replace the transfer case seal as it was leaking and they replaced the fluid as well. I think the transfer case takes 1.5 quarts, so there's not a lot of cost involved.
gian13
10-02-2017 08:47 PM
