This light just came on, what is it?
Hello everyone
As I'm driving my car this light came on and it won't go away. This isn't the traction control off button as that says "off" when I toggle it.
Please help? Thanks
Please help? Thanks
Not sure, that light usually comes on only briefly when your wheels have lost traction. If its on solid my gut would say that the DSC sensor needs to be checked or replaced. Have never seen something like this before so maybee someone else wants to chime in if they feel differently. It look like yours is a newer coupe (2010+) so run it to a dealer and have em check it if your still under warranty...
That light is what they call the VDC =known as Vehicle Dynamic Control which also work off the ABS system several things it could be causing the failure and light to remain on. Would need the DTC code stored in the ABS system to know further
I had that same issue once before. Especially if I drive up or down ramps. Check your brake fluid if its low. Usually that light would pop up because I was low on brake fluid and when my car would either go up/down a ramp, that low fluid would tip the sensor and stay on until I shut the car off. Top off the brake fluid and see that resolves the issue.
Gefartenblatz
11-10-2015 11:45 AM
MEH2013G37
09-24-2015 08:37 AM
pcwd
09-15-2015 10:06 PM
B Feelgood
09-13-2015 05:56 PM
