RJM Performance Clutch Pedal Assembly
Old 02-01-2018, 02:28 PM
  #286
Entcee
Entcee's Avatar
Lowering AFP causes a raise the initial friction point, makes the clutch feel heavier, and narrows the modulation zone.
It is something you will need to play with. Try 70, then 65, etc...
Old 02-02-2018, 07:46 PM
  #287
Davpal
Davpal's Avatar
put my rjm assembly in two weeks after i bought my car and love it . it been two years and 10,000 miles and no issues . kept all my settings as it came just adjusted the pedal to the same height as the brake pedal .
presidentsdad (02-03-2018)
Old 02-03-2018, 10:00 AM
  #288
presidentsdad
presidentsdad's Avatar
I might just move the actual pedal down instead of adjusting the AFP...thanks for the suggestion.
Old 02-07-2018, 06:33 PM
  #289
presidentsdad
Did just that, seems to be OK, but now trying to fiddle with the exact seat position to get a repeatable super smooth launch (without burning up the clutch).
Old 02-12-2018, 12:00 PM
  #290
presidentsdad
I found it, I found it! This one is juuuust right! Thanks everyone.
Old 03-14-2018, 07:56 PM
  #291
MS64MEE
MS64MEE's Avatar
Was driving home the other day and car stalled very abruptly. This was very strange since I did the spring swap years ago. When I got home found these on the driver side floor. Glad I found this thread. Will be ordering RJM shortly.
Old 03-14-2018, 08:35 PM
  #292
Gio37
Gio37's Avatar
Same thing happened to me a couple of years ago LINK
Anywho....when the bracket broke I had it welded the same day and it was back in service. A little after that I got the RJM pedal assembly
g/l
Old 03-15-2018, 10:30 AM
  #293
presidentsdad
You'll not be sorry. It's a an "upgrade" that should have been standard in my book.
Old 03-15-2018, 11:00 AM
  #294
MS64MEE
MS64MEE's Avatar
g/l
Too funny Gio37! I've been off the forums for a while (based on date of your post, longer than I realized). Fortunately, I work from home so don't need the car (in a pinch, I guess I can roll in my wife's oh sooo cool Sienna LOL).
Old 03-30-2018, 09:43 PM
  #295
MS64MEE
MS64MEE's Avatar
Just got the pkg. will do the install the weekend. been awhile since I wrenched on the car so should be good times
Old 03-30-2018, 09:49 PM
  #296
Gio37
Gio37's Avatar
Just got the pkg. will do the install the weekend. been awhile since I wrenched on the car so should be good times[/img]
Well worth it
Old 03-30-2018, 10:12 PM
  #297
Calg37USMC
Calg37USMC's Avatar
Recieved mine eailer this week. Ryan was very communicative and a pleasure to do business with, highly recommend!
Daddy Fat Sacs (04-04-2018)
Old 04-04-2018, 11:46 AM
  #298
MS64MEE
MS64MEE's Avatar
Done and very pleased
Thanks for all the tips guys. Taking out front seat made it a cinch. Found some of the steps in the instructions like removing side trim weren’t needed. Nor was the soapy water to install pedal cover. In terms of difficulty, this was pretty easy. Maybe 3 or 4 on scale of 1-10.
Only nit to pick about design is the fact the part uses so many different size nuts and bolts, both metric and SAE. Not huge deal as most of as both but limiting design to couple sizes would make it easier to just deal with just couple size wrenches/sockets instead of groping around the floor among half a dozen.
This is definitely a great mod and worth every dollar I spent. It affects every minute you drive the car. The spring swap was a nice improvement over stock but this part takes it to the next level. Shifts are so smooth and effortless now. It just works the way it should.
If you are on the fence about this, jump off and just go get it. You won’t regret!
Old 04-04-2018, 12:16 PM
  #299
Received 4,711 Likes on 3,519 Posts
Another voice in the choir, exactly in tune with other comments. Particularly coming from the spring swap to the RJM.
Good for you, MS64MEE.
Old 04-04-2018, 04:58 PM
  #300
kapag37
kapag37's Avatar
One of the first things I got for my G was this along with exedy stage 1 clutch/flywheel. Feels a lot better than when I first got it.
Quick Reply: RJM Performance Clutch Pedal Assembly
