RJM Performance Clutch Pedal Assembly
#272
Well....I finished. Let me explain...I'm a very experienced DIYer. I do my own brakes, sparkplug changes, fluid flushes, oil, etc...but under the dash is the worst bleepity bleep place to work. It took nearly 3 hours and a fair amount of cussing...and probably several days of payback from my back and hip (and right knee).
But OMG...WHAT A DIFFERENCE!!!!! I've been driving manual transmissions for over 30 years....this went from WTF to OMG!! Before it looked like I had never driven a manual transmission before to now it is smooooooth! THIS is how is should be from the factory!! Thanks for all of the suggestions (especially the ground mat for the knees and the blanket for the door sill!) I'll probably never adjust it because the items to adjust are a major PITA to get to.
Glad to hear you got the same reaction as just about everyone else whose completed the install. Night and day and best mod for 6mt's imo
#273
You probably want a shorter boot to go with your short shifter so it doesn't bunch up.
https://www.redlinegoods.com/
#278
Lego's boot does look good, in proper leather, and perforated. However, I think the shifter area is better suited by stitching a four-panel boot, instead of three-panel. Here's the same, but in Redline's Charcoal leather, with matching charcoal stitching, selected to work with a Stone Leather interior.
Rochester (01-25-2018)
#281
Yeah, the rear 2 points are closer together and the stitching makes it look too busy IMO. Maybe the Infiniti designers thought the same thing as OEM is 3-panel . It may look completely different in person, and of course, this is only my opinion and you are right, no wrong answer
#283
I thought I'd share this. I exchanged a few emails with Redline and asked them if they could make the G37 a car of the week. I figured it was worth a shot...well, they did! 20% off all orders.
https://www.redlinegoods.com/CarOfTheDay.php
#284
Still driving around with a smile on my face! But it seems I may have too big of an engagement window now. Still in search of the Goldilocks spot. Questions for those that have adjusted below the 75% mark. Did it lessen the engagement window? How far did it move toward the floorboard. How far less than 75% did you go? Would you do it again? I ask, because getting in there to make adjustment is a giant PITA.
