Slow downshifts/Grounding Kits
I have a 2012 G37 Sedan 7 A/T and was wondering if adding a grounding kit would help with my downshifts. Or these a fact of life in the new 7 speeds? My biggest gripe about my car are the sloow downshifts. Going 40-60's i feel like the downshifts are terribly slow. Usually by time it decides to downshift i no longer need it to. Anyone have a positive experience in using grounding kits to help this? I haven't really heard of anything else helping, but these kits, and thinking it's worth a try.
Thoughts? Any other options? Take it to the dealer and complain??
I guess some added info is i am running Stillen CAI, stillen HFC, uprev tune (had stillen exhaust, but had too much drone so i sold it and put stock back on), but the guy that tuned it says the tune has nothing to do with shifting or shifting points. I dont know enough to know if that's true or not. bringing it to another shop that does uprev tunes soon to see what they think. if i dont get it where i want it i am going back to stock with it. i feel like the CAI hurt the low RPM band.
@HoldmyMouse- mainly referring to computer downshift. no manual mode. although when i am in manual mode and upshift it does take it a bit to shift then as well. i've read the grounding kit may help with this. seems people are on either side of the fence, but right now i don't know what else to try and biggest harm is i waste a few dollars.
@broski28- if only I had DCT! lol i really wish i would have skipped the G and got an S4!!
@rexhavoc- i bought it new and only have 39k on it. cant imagine the throttle bodies are that dirty. i have reset my ecu a few times as well and no luck.
That's about what I had on mine when I cleaned them as well. They weren't awful but they were a little sticky. You'd be surprised. I seafoamed at the same time since I was already into it. Will probably do the same this weekend if I change my plugs.
IMO a Stillen CAI will impact your low end and mid range though generally seems to increase your top end. I'm running the R2Cs which seem to give me some gains in the mid-range. I'm tuned with EcuTek which has had a slight positive impact, or perceived impact, on the shifting.
I forget what I paid for the BB kit but it served me well; only took it off to use the new one that matches the bay better.
I cleaned my throttle bodies at 30k miles. I was surprised to say the least. Not a ridiculous amount of build-up, but enough to make the task worth it. I didn't disconnect any of the TBS electricals nor did I move the butterfly valve (debatable topic), and fortunately I didn't have to perform the idle air relearn procedure as some have. Even if I would have, cleaning the TB's has become part of my every 25-30k mile maintenance routine as I was pleased with restored throttle input and responsiveness through the gears.
Although it's the downshifts the OP is focused primarily on.. considering how finicky and sensitive it seems our engine management is to TB input, I'd try and see what cleaning them yields.
as far as what others have mentioned (cleaning throttle body), that is something that I do as well...in addition to cleaning the MAF sensors. I don't have a CAI but have aFe dry filters with the stock air boxes.
If you decide to take your car to the dealer for the Transmission TSB, just be sure to go back to your tuner beforehand so they can save your tune and flash your car back to stock...after you get the TSB completed, go back to your tuner and have your tune put back to your car... My M35 had the accelerator pedal recall which Infiniti had to flash the ecu, so prior to me getting the recall done, I went to my tuner -- as mentioned above.
hope this helps....
any certain brand recommended for the grounding kits? only ones i can really find are the stillen ones and read some mixed reviews of them on here.
ill have to check into cleaning the throttle bodies (although my shifting has been like this since day 1). i live in the city and have no garage, so my only way to get work done is the a dealer/garage :-x
i haven't. not even sure if there are any. i bought it new in 11-2011 as an 2012 model. do you know if there's an update for it for sure? also, i think i have to get my uprev tune removed, get the update, and then get the tune redone or something. not quite sure.
