Uprev question
To use it , Flashed tunes ,log runs is VERY easy . I messed with a lot , even found out that I could shut the tire light off So swapping rims and tires you wouldnt have to get TMPS's. You can just shut the light off.
I could even walk you thought things you need help with .
There are ways to reset. There's a forum DIY post on it. Likely you have one going bad or battery is going in which case you'll have to replace it first. The only ways I've heard to stop the light require more cost than replacing your TPMS sensor (I think things like UPREV could do it). Maybe someone else knows of one.
If you open Cipher, and its under BCM monitors. You can shut it off I did it a few times with the car running, Off/ ON the light on dash went out, there is a few things in there you can touch, lights,auto door locks etc.
RadioFlyer (06-23-2015)
Yeah that's what I thought you were talking about, but when I did that on my car, it shut off the light, but it came back on 5 seconds later on it's own. I can toggle it on and off, but then when I leave it, it comes back on.
nbast
09-14-2015 12:39 PM
