Frozenboost - heat exchanger or front mount intercooler?
trying to order this Frozenboost heat exchanger for my Stillen supercharger. there's no contact on the website and I have no idea what to order. someone wanna help with this?
I just ordered mine. I used the link from the other thread:
https://www.frozenboost.com/water-to...7f10f7aea980af
I just ordered it from the site, straight to checkout and paid with paypal. I should be receiving it by the end of the week, and installing this weekend, hopefully. I'll update how it goes. One thing is that we'll probably have to flip our bumper beam upside down to get the tow hook out of the way. That wasn't mentioned here, so maybe it isn't an issue on the G front end. But there's a lot of info about it over on the 370Z boards.
willstophe (06-11-2015)
uuuhhh I just talked to the sales rep....the cooler doesn't come with piping. and he doesn't know which one we need to get for our car. we're screwed.
The fittings should be the same as the ones on the Stillen unit. The question is if the Stillen hoses will be long enough. I guess that will depend on the final mounting position.
It does not come with fittings... you will need to buy two threaded ones at any auto supply place. Got mine at Mopac. Get right angle ones. The hoses are long enough... just, on one side and on the other you will cut off a few inches. The Stillen one uses lame push on fittings. The other thing that I did was to trim off the brass drain nozzle at the bottom of the FB intercooler as it sticks out past the bottom of the bumper. You will also have to notch the bottom of the bumper slightly. you will ned to build a couple of custom brackets to mount it under the bumper... it fits perfectly. I offset mine slightly to maintain access to the tow bracket.
Thanks to ANMVQ for putting me on to this intercooler. It makes a HUGE difference.
It was a bit of fiddling around... an afternoon project. 2-3 hours at a leisurely pace. You will need to drill holes in the bumper to attach brackets to hold the intercooler. Your'e not doing it yourself LOL
I tried to attach pics but had some grief. You will laugh when you see how wimpy the Stillen cooler is compared to the FB.
Its in between the coolant pump and the mani is correct it replaces the SMALL one that Still attaches to the radiator. I improves the cooling radius but like 10 times . The length and depth of it give you a huge boost of the Stillen one.
It gets it away from the radiator and gives you options on upgrading the pump,coolant tank and or adding cooling fans if your tracking it.
No problem man, This is on the MUST list if you have this kit
I'm not going to lie....I am very nervous about fitment issues if there's drilling involved....and brackets? It didn't come with brackets....drilling holes in my front bumper? This sounds like it can turn awful. Idk how I feel about a 25 lb part being held on my car by a set of brackets that didn't even come with it and let alone the idea that these brackets have to be mounted via drilling holes in the bumper? Basically the unit would be held on the car by the bumper? that sounds pretty scary.
The coolant capacity is also much higher with the bigger intercooler so you have more fluid in the system to dissipate heat.
