2012 6MT Clutch issue.. more of a noise then issue
Hey guys so my clutch has been making a weird noise started 2 days ago. The clutch is fine i can shift fine everything feels normal until i press it and let it go while either OFF or ON. It makes these clicking/creaking/rattling noise.. Ive tried to look it up using the search button but only found this forum
https://www.myg37.com/forums/g37-sed...dal-noise.html
^^ that is the exact noise
No one really said it has been fixed or anyhting so i wanted to make sure. I dont know if i should bring it to the dealer cus San Francisco Infiniti dealer is not too helpful.. And they charge up the butt! Any one have the same issue with 6mt? My car only has 20k miles.
The RJM clutch pedal is pretty loud by comparison (mostly due to one of the springs).
If you went down there and depressed it with your hand you can probably pinpoint what might need a little lubricant to quiet it down. It might be the master cylinder or just one of the joints in the clutch pedal arm assembly.
But overall I wouldn't worry about it. The dealer will probably just coat the entire thing in grease. And honestly, even my though my dealer has mostly been accommodating, half the time they try to fix something they screw up something else.
My thigh bolsters actually make more noise than the clutch pedal when I move my leg to press in the clutch.
Cr0tchf4i
08-19-2015 03:52 PM
Digilog
08-17-2015 03:54 PM
