Rear Differential
Old 03-17-2015, 09:23 PM
blkceaser
blkceaser's Avatar
Rear Differential
I'm trying to order a rear differential for my car but I'm not sure as to which one I should get. I have a 2010 G37x AWD...please help
Old 03-18-2015, 09:41 AM
blkceaser
blkceaser's Avatar
Will a locked rear differential keep the transmission from engaging?
Old 03-18-2015, 12:18 PM
jpg37
jpg37's Avatar
If your are changing gear ratio, you will need to change the front also.
Old 03-18-2015, 02:19 PM
HoldmyMouse
HoldmyMouse's Avatar
IIRC It has been done already. Just get the sport vlsd which is the same ratio and you are good to go.
Old 03-18-2015, 02:37 PM
vqsmile
vqsmile's Avatar
Why would he be OK putting a VLSD in his AWD model?
2010 Infiniti G37 Coupe Specifications | Infinitihelp.com
Old 03-18-2015, 03:21 PM
HoldmyMouse
Because 7sp auto sport has the same fd ratio as the x.
Old 03-18-2015, 06:34 PM
vqsmile
vqsmile's Avatar
. . . and what about the vlsd ?
Old 03-18-2015, 07:21 PM
Ryne
The Steering Wheel Guy
Ryne's Avatar
This is a hot topic and I personally think the VLSD will throw off the sensors and everything with the AWD system. The system is sensitive and can't even have over 1% difference in front to rear tire diameter so I have a hard time thinking this would be a painless swap, or even beneficial.
I see the benefit of changing the final drive, but you certainly cannot do this on the AWD without changing the front, and there isn't any parts available for that. The traction, stability, and AWD system are going to make the LSD unnoticeable, even if the swap works perfectly.
Even though Infiniti says that the xS coupe gets an LSD, I would love to see someone jack up their rear end and spin one wheel to prove it once and for all.
Old 03-18-2015, 07:54 PM
vqsmile
vqsmile's Avatar
My thoughts exactly. They didn't even offer the VLSD in the X coupe until 2012, and given the complexity of the system, I just don't see how one can assume that the AWD control system calibration for a 2010 model will react favorably with a retrofit.
Old 03-18-2015, 09:02 PM
HoldmyMouse
Quick search shows I did recall correctly it has been done.
https://www.myg37.com/forums/engine-...-on-awd-g.html
You need to understand VLSD is not as potent as a mechanical LSD so the locking action isn't as strong. Slippage will still go through but will be in a more limited fashion which should not interfere (as much or even at all) with the AWD computer.
Old 03-19-2015, 12:01 AM
VQ-Vic
VQ-Vic's Avatar
I just had a question after searching and looking up specs on the final drive.
Are all 7AT LSD all 3.357?
Have they ever made 7AT LSD with 3.69?
I am looking for the 3.357 LSD diff, and I wanted to make sure as the place I am looking doesn't say if it has 3.357.
Old 03-19-2015, 12:34 AM
HoldmyMouse
07-08 5AT has 3.692 should be direct bolt on with no messing with changing any flanges but only if you are Rwd
Old 03-19-2015, 12:58 AM
vqsmile
vqsmile's Avatar
Maybe you're right, but it could also just be empirical evidence, and a very limited sample at that.
Old 03-19-2015, 10:15 AM
serega13
serega13's Avatar
VLSD turns into an open diff once it gets some miles on it, something around 60-80k. It cannot be fixed as it's a sealed unit. If I was replacing mine, I'd throw on higher final drive one, like 4.08. Although I have no idea how it would work on awd, I've replaced a few diffs but it was always on rwd cars.
Old 04-10-2015, 09:57 AM
blkceaser
blkceaser's Avatar
Ok, thanks guys but I have another question. I just found out the that the rear differential has seized up. Not sure if any gears have been stripped or anything but any suggestions on the steps I need to take to fix this or do I just buy a new differential?
Quick Reply: Rear Differential
