Performance Mods!
Old 12-17-2014 | 12:02 PM
  #61
alfredo24pr's Avatar
alfredo24pr
Do the gear swap. I don't remember if you are 7AT or 6MT. Depending, you could go 3.9 or 4.08
Old 12-17-2014 | 12:53 PM
  #62
G37Xtreme's Avatar
G37Xtreme
Not to hijack, but curious...
Has anyone changed gear ratios with a 2010+ AWD G37x?
Old 12-21-2014 | 07:21 PM
  #63
bos3ayd's Avatar
bos3ayd
I'm 5AT, 2008 model.
so u mean i should change my gear.
Old 12-22-2014 | 12:06 AM
  #64
alfredo24pr
Originally Posted by bos3ayd
I'm 5AT, 2008 model. so u mean i should change my gear.
I don't know about the gear swap on the 5AT, but I think you would need a 6MT LSD differential and the 3.9 or 4.08.
Old 12-23-2014 | 06:20 AM
  #65
kpjc4eva's Avatar
kpjc4eva
Top mount twin turbo kit. 62mm turbos X2
Custom made intercooler
Custom made radiator
Fully built block
Fully built heads
Custom built manifolds
custom straight pipes
Head studs
Main studs
A bunch of technology stuff in the car to read the car stuff.
Along with a lot of headaches from this 2 year build. Finally coming to an end. Yay.
Old 01-13-2015 | 08:10 PM
  #66
PongSanity's Avatar
PongSanity
Rebuild the block! Up the compression! Big Brake Kit! Quaife LSD. Tighten up your suspension. Weight reduction! Still on that nitrous tip plus methanol. Upgrade fuel system to support e85 or c16. The s/c is great for daily and stillen has an air to water kit to keep it cool and squeeze more power out of. Hit up diego@vossen about his supercharger g37 and follow SharpByCoop for the 4.08 gear swap in a 5 at g37
Old 01-14-2015 | 10:15 AM
  #67
smakfactor1's Avatar
smakfactor1
Fully built block
Fully built heads
Head studs
Main studs
Pictures or it didn't happen.
Old 03-23-2015 | 05:16 PM
  #68
beers64's Avatar
beers64
Has OP looked into bored throttle bodies?? Synolimit tb perhaps? Wondering because i was also considering this mod.
Old 03-27-2015 | 02:17 AM
  #69
PongSanity's Avatar
PongSanity
63mm TB FTW!!!!
Old 03-27-2015 | 09:02 AM
  #70
beers64's Avatar
beers64
Originally Posted by PongSanity
63mm TB FTW!!!!
Pong where did u get yours done? And how much was it? Also, is 63mm the standard upgrade?
Old 03-27-2015 | 12:40 PM
  #71
ANMVQ's Avatar
ANMVQ
He got his done by Synolimit( I think)
Old 03-28-2015 | 09:01 PM
  #72
PongSanity's Avatar
PongSanity
Yeah SYNOLIMIT is who's the TB plug for the low. Cheaper than z1 by FAR. and I enjoy this mod.
Old 03-28-2015 | 10:01 PM
  #73
beers64's Avatar
beers64
Yea that's what I've been reading. Decided I'm going to get the ported tb's, ported lower intake and ported m370
Old 03-30-2015 | 01:26 PM
  #74
ANMVQ's Avatar
ANMVQ
You have M370Z? Selling mine :/ , I have I'm also getting my lower ported this weekend.
The SYNOLIMIT is a hit or miss I think I had a good smooth transaction with him but others haven't ?
Old 03-30-2015 | 01:57 PM
  #75
beers64's Avatar
beers64
Yea I've read a lot of places that everyone has had a smooth transaction with synolimit (sean) but not with one of the guys he was working with (scott)
No I don't have one he has one ported already tho. Is yours ported? If so, how much you looking for?
Quick Reply: Performance Mods!
