VLSD on AWD G
#31
The easiest option for you would be to source an auto g37 sport (3 flange) diff. it'll be a direct swap. You can also source a VLSD from an auto 370z with sport packages and nismo models. These will also be 3 bolt input flanges and will be a direct swap.
In the event you find a mnaual g37/370z differential (4 bolt flange), you can still swap the input flanges but its more work.
#32
Moderador
Journey and base model rwd came with open differentials. No awd (even the G37XS) had vlsd.
#33
Looking at it a CUSTOM ADAPTER SPACER would work perfectly. One that accept the Auto DS and bolts to the 4 bolt flange. In the auto you have the rubber donut which this could be messed with to work. It would be a lot easier than changing the flanges. Just nobody makes them.
If someone could have an adapter, i can see it selling decently sell, since sourcing 3.6 from manual g37 and 370z is easy and fairly cheap for auto folks.
#34
This is awesome, I will attempt this in my 2011 X sedan. Just to be clear, you can swap in a 3-bolt vlsd and replace the original 6-bolt flange? Aside from trimming the centering shaft, there's no modification needed for the driveshaft or axle shafts?
#35
As far as the axle shafts, usually apparently the G37 LSDs have a threaded opening for the bolt. But for my G35 it had a flat opening so the bolt could go right through.
#36
The 3-bolt input flange is easily removed after removing the 30mm nut and pulling the flange off.
I just sold a manual 3.69 diff and sold it with a 3-bolt flange i pulled off an auto from the junk yard.
misc
17
12-24-2019 05:13 AM
Slapshot1
09-27-2015 08:40 AM
