belt need to clean or change. ..
Old 08-06-2014 | 09:22 AM
PongSanity's Avatar
PongSanity
I wanna say clean but I just wanna hear what the forum has to say...
G37 start up:
Old 08-06-2014 | 09:33 AM
08skyline's Avatar
08skyline
Belts can't be cleaned unless you know something got on it. Depending on your miles it would need to be changed or just need to be re tighten.
Old 08-06-2014 | 09:43 AM
PongSanity's Avatar
PongSanity
48K ... so spraying belt conditioner wouldn't help? i don't notice any cracks in the belt and i think a drop of oil dropped on it whilst checking oil... and the belt doesn't have any play in it. it's still stiff.
Old 08-06-2014 | 09:50 AM
You can clean a belt if you have something on it. You can use belt conditioner. However before even considering that make sure the belt is in 100% condition and is properly tightened. If its glazed, brittle, frayed, or has tiny cracks in the ribbed side, or worn in any other way go ahead and change it out.
Old 08-06-2014 | 10:12 AM
PongSanity's Avatar
PongSanity
Give thx black betty
Old 08-06-2014 | 12:49 PM
GW330's Avatar
GW330
That sounds weird, sure its the belt?
Why do older G37s start up so weak? Mine (08 G37) starts up the same even after I changed the battery?
Old 08-06-2014 | 03:28 PM
PongSanity's Avatar
PongSanity
That's what I suspect because I only hear the squealing at the startup. Never again until the car has cooled down. I'll change it the belt. Did some research and belt conditioner doesn't do serpentine belts any justice. ..
I read somewhere that the alternator clutch doesn't kick in until after 8 miles or a periodic time frame. ..
Old 08-06-2014 | 03:48 PM
GW330's Avatar
GW330
Maybe the tensioner?
Found a DIY on how to change the serpentine belt
https://www.myg37.com/forums/d-i-y-i...an-09-g37.html
37
10-17-2020 11:12 AM
beng37s
12-08-2019 01:21 PM
Stevolkz33
05-28-2016 02:36 AM
Mr Infinit
10-16-2015 09:43 AM
timc00k
10-09-2015 01:20 PM
Quick Reply: belt need to clean or change. ..
