Seeking Advice on 5th gear grind/6MT questions
Old 06-04-2014 | 11:13 PM
Zack342's Avatar
Zack342
Originally Posted by Jsolo
^^I can't say with certainty. Maybe some longer time owners can chime in on whether there were any internal revisions in the MT with later model years.
I mainly switched to the MT85 early on to try to cure an annoying whine in warmer weather. The sound lost some amplitude but is still present. When it's 60F or cooler outside, the noise is barely audible.
what are your thoughts on the amsoil
AMSOIL Manual Transmission & Transaxle Gear Lube 75W-90
Old 06-07-2014 | 06:04 AM
nauticapinoy's Avatar
nauticapinoy
Originally Posted by din9leberry
Hello all,
I am in the market for a G37S sedan, one with a 6 speed manual transmission. After scouting much of the internet with 370z/g37 5th gear grinds, I am inconclusive on a few areas.
I test drove a 2012 G37S sedan and experienced this 5th gear grind, 2 out of the 3 times I put the car into 5th. At first I apologized to the sales guy, till I realized after the second time it wasn't me . I asked him why and he said its because the car has been sitting for a while...which led me to google the issue. I am not new to manual cars, my last car was stick and its not user error here.
Its under warranty with only 40k miles. But what bothers me is that its really inconclusive if the problem has been fixed. All I read about is the trans being replaced numerous times...
So owners, was/is there a updated transmission that fixed this issue? I do not want to dump $30k+ into a car only to have a serious powertrain issue, that will resurface eventually (and more importantly), after warranty.
Thanks in advance.
You lookin to upgrade too huh? I'm nauticapinoy from tsxclub.
Old 06-07-2014 | 08:09 AM
Glenn2008's Avatar
Glenn2008
I had my tranny replaced under warranty for 5th gear grind at 69,960 miles.
Old 06-09-2014 | 10:25 PM
Zack342's Avatar
Zack342
Guys who've had transmissions replaced, how long does it usually take them?
Old 06-10-2014 | 10:39 PM
Glenn2008's Avatar
Glenn2008
Mine took \two weeks, they were waiting on some line. The transmission came within a week.
Old 06-11-2014 | 11:44 AM
Byrdman's Avatar
Byrdman
Don’t Buy From GTM/Gamma
The dealership I went to only had it for 2 days.
Old 06-11-2014 | 02:11 PM
WhiteG_6MT's Avatar
WhiteG_6MT
I took mine in on a Tuesday and had it back by the following Tuesday.
They also replaced the throwout bearing and the clutch slave cylinder. Said my clutch was in excellent condition (35k miles).
Post op: It shifts much smoother than the previous gearbox, regardless of gear and the clutch seems to work better as well but that could easily be placebo.
If there's any question and your MT car is under warranty, take it in.
Trust me you won't want to pay for this repair out of warranty.
Old 06-11-2014 | 08:23 PM
Glenn2008's Avatar
Glenn2008
^I was surprised that they replaced my tranny. The only time that I had any gear grind going into 5th was when it was cold. Once the oil warmed up, it shifted smoothly. The dealer told me to leave it with him and he would have one of is techs check it out in the morning. They did and confirmed my findings. So now with a new tranny, It's like having a brand new car.
Old 06-18-2014 | 03:08 PM
Zack342's Avatar
Zack342
they are replacing my tranny and clutch/ fly wheel
Old 03-10-2015 | 08:15 PM
SkylineG's Avatar
SkylineG
Had the 5th gear grind as well. Was still under warranty and dealer replaced my tranny, no more grind.
Old 03-16-2016 | 03:18 AM
claudiohv's Avatar
claudiohv
I'm experiencing this now, car is at 12x xxx KM...
09 6mt will bring it to my mechanic and see what takes place. Will the delearship still replace it for free? I think I still have powertrain warranty left on this car.
Old 04-03-2016 | 05:05 PM
hooey_b's Avatar
hooey_b
It's definitely the syncro. I had the same problem a few years back and pinpointed it out, then took it to the dealership. Had a hard time trying to tell the dense a$$ mechanic AND master mechanic that all i needed was a new trans, or syncro if they wanted to dive that deep. A$$hat replaced it AND the clutch and flywheel, talking bout it was "standard troubleshooting procedure".
Either way, you're going to want to replace it. The sooner, the better.
Old 12-24-2019 | 03:32 PM
joe32288's Avatar
joe32288
I've been experiencing the 5th gear grind for a couple of years now. Didn't think it was a big deal, but today while driving I think the tranny finally went. I lost 6th gear, but still had 5th. After getting off the freeway I tested out the other gears. I had 3rd, 4th, and 5th. 1st, 2nd, and 3rd gear were just spinning like neutral, and neutral stalled out like it was in gear. After driving some more, the problem seemed to fix itself for a bit, but shortly came back. It seems like depending on how I'm driving the gears will shift in and out of place. If it goes out of place, I can kind of get back on track by moving the shifter through the different gear positions. Am I for sure looking at a tranny replacement? Can someone explain what's going on inside the transmission?
Old 12-24-2019 | 10:29 PM
  #29
AdamBritt's Avatar
AdamBritt
So I can't explain it but I had that happen in my 944 a long time ago. On that car at least it was the shift linkage that had gone causing me to lose some gears completely but still have a few. I was 17 I think and had no idea what was happening, made it half way across town before I had to call a tow because I lost everything. My mechanic who is a local independent was able to fix it relatively cheaply and it held up just about forever. I think I took it back in once for that same issue.
Old 12-24-2019 | 10:30 PM
  #30
AdamBritt's Avatar
AdamBritt
Also this thread is making me want to check what the timeframe for transmission warranty on my car is. Doubt I'm still in it since mine's a 2011 but I kind of hope if this issue is going to happen it comes up and I can get it replaced under warranty. Just hit 42k miles I think.
redlinernyc
02-29-2016 11:06 PM
Simran Mann
09-13-2015 01:51 AM
inspector94
09-08-2015 12:57 PM
Detailed Image
Lighting/Cleaning Products
09-04-2015 08:14 AM
ZachThomas
09-03-2015 01:40 PM
Quick Reply: Seeking Advice on 5th gear grind/6MT questions
