Error code... Ideas?
So I have this crazy error code in my new transmission.
I was wondering if anyone had it before.
P0729- AT 6th gear incorrect ratio...
I mean wtf!
I am going to try to do some re-wiring but I wanted opinions if anyone has any ideas or if this has happened to them.
PLEASE!
I mean wtf!
PLEASE!
They say its something to do with aftermarket parts that are making the error code and they wont touch it.
P0729 NISSAN - Automatic Transmission 6th Gear Incorrect Ratio
Possible causes
- Low transmission fluid level
- Shift solenoid mechanical fault
- Hydraulic circuit fault
- Transmission failure Help with this
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Transmission will not shift into 6th gear
P0729 NISSAN Description
This malfunction is detected when the A/T does not shift into 6GR position as instructed by TCM. This is not only caused by electrical malfunction (circuits open or shorted) but by mechanical malfunction such as control valve sticking, improper solenoid valve operation, etc.
Possible causes
Symptoms
Well infiniti checked my car over and said everything was perfect on it. No issues. They said it had to be something I did to the car myself with electronics or mechanics that are aftermarket.
The issue is that how could it be mechanical if they changed the whole tranny?!? It cant!
Therefor it would have to be electronic no?
The car shifts up in gears all the way to 7th fine. Although it wont downshift in auto mode if I step hard on the throttle. It will just stay in the highest gear. So for now I am just driving in manual mode all the time.
37
10-17-2020 11:12 AM
butwhatuptho
10-04-2015 07:51 PM
mikysee
09-28-2015 11:18 AM
