max horsepower potential of stillen supercharger
How much horsepower can the Stillen supercharger produce for a G37 AWD sedan with a built motor and meth injection? What is considered max horsepower potential?
Probably depends on how safe you want to be.
The stats on here show that without building the motor you can push safely around 500hp and 400lbs tq but with more mods and internals you could push that almost as high as you want depending on what work you do to it. But at that point it would be smarter to go buy a GT-R or something as it would be cheaper
already completed the motor build. Been waiting on a GTM Twin turbo or a twin supercharger but it doesn't seem like that's gonna happen. Also been waiting for the trans upgrade. Doesn't seem like that may happen either. I guess it's time for plan B now. My Goal was minimum 600 wheel horsepower. I didn't know if the stillen supercharger is capable of that
markg37xs (03-06-2014)
Motor build has been done. I've been waiting on a GTM twin turbo kit or a twin supercharger. whatever can be done quicker but it doesn't seem like that's going to get done. I've also been waiting on my transmission,that don't seem like it's going to get done either. I can live with at least 500 wheel horsepower.I don't know of any other kits available for the all wheel drive sedan
I'm sitting at 550whp 410/lbft with a stock motor and meth (meth not tuned) with my GTM Twin SC kit. It has the 92mm pulleys and they go down to 84 I believe. On a built motor and meth, I don't doubt 650+whp is possible.
Hey SS, How long ago did u get the kit and was your kit made to order like mine. GTM had my order since the beginning of October 2013. They said it would be done in Dec, then jan and then feb. same thing with my trans that they have, also since October.
I actually told them to send either one of the kits (twin turbo or twin supercharger) whatever one can get done quicker
well im on stock internals and im pushing 520s on E85.... you can make the super charger pulley the same and get a larger crank pulley to up the boost.... that blower is rated at 15 psi all in im sure you could hit the 600 mark.... if im stock and making that power im sure an extra 70 hp is possible
Is that GTM Twin SC in a 370z. If I get the GTM twin SC it's goin in a G37 AWD sedan. Being AWD I'm gonna get lower whp as opposed to a manual trans. Probly not alot less, but I would like to see something in the range of 600-700 whp.
all depends how much power that front diff and the transfer case can hold.... infiniti says the stock trans and rear wheel drive parts can hold anywhere from 625-650 to the tire but that pushing it...
