Opinions Needed!! Infiniti says this sound is normal
and dealer says its a normal noise, what the tech said "this is a normal noise once the clutch and flywheel are broken in it gets a bit louder" im like WTF.... 40+K car makes noises that not even a honda civic makes? interesting.... i guess thats there way of saying "fvck off we dont know what it is"
Seems to be a pretty common problem with the 6MT 370Zs. At least that's what I gathered from visiting their forum. Chattering clutch. They seem to just live with it.
Correct the chatter is the transmission which is a common problem. Clearly here the grannyiisn't the issue. The problem comes when the clutch is pressed in and it's ticking not chatter
Yea chatter comes w/ the clutch pedal up and untouched at idle. It's not a problem, just noisy the way it was designed. For what we are talking about, the pedal is pressed in, there is no chatter. The transmission should be 100% silent since the clutch is disengaged, there is nothing to chatter. But there's a ticking/knocking noise coming from the transmission.
It's a bearing somewhere. Just don't know which yet.
^ i have that exact issue. a rattling or knocking when the clutch is disengaged. i can "feel" the noise through the shifter. since it has to be a rotating element, i'm guessing the throwout bearing/CSC. i was at the dealer last week and will be going back next week for further diagnosis. the service rep hadn't properly relayed my complaint so the tech spent all his time chasing another issue.
I hope you guys get your issue resolved as quickly as as cheaply as possible!
Nothing worse than having something wrong with an otherwise perfect car. Drives you crazy.
The last dealership i went to told me it is the throwout bearing but that this is "normal" for it to make that noise. Stated even a brand new one will make that sound.
Same here. The dealership by me is useless. I am meeting with a new district rep on Nov 5th at a dealer about a hour away. Annoying i have to drive that far but at this point I just want it fixed
#29
#30
I can't view the video at the office but I hear noise when my clutch pedal is engaged (all the way up) when I'm in neutral. Once I press the clutch pedal down, it goes away. Totally normal from my online research, asking at an Infiniti dealership, and asking my local Nissan mechanic.
I do have weird creaking sounds and light ticking feedback that can be felt through my clutch pedal and shifter. I've recently replaced my master cylinder and am going to get my new clutch and CSC installed this weekend. I can report back to see if any of my issues are fixed and maybe it can help out someone else?
