Engine compatibility between models? VQ37VHR
Old 09-24-2024 | 03:53 PM
  #61
projectpanda13's Avatar
projectpanda13
Originally Posted by QVQ37
okay so with all this info being took in I have a 08 g37s coupe that blew a head gasket . I’m replacing it with a 2014 q50 3.7 will I need the ECU from q50 ?
Reuse your g37 ecu. This is because you are reusing your g37 engine harness.
Old 09-24-2024 | 04:43 PM
  #62
Grob's Avatar
Grob
This is correct. No need to switch ECU over. Just use harness from 08. You will possibly need the O2 sensors from your old car if the new engine comes with them. Have heard the connectors are different.
projectpanda13 (09-24-2024)
Old 09-24-2024 | 04:46 PM
  #63
projectpanda13
For VHR there were 2 different plug types.
You can reuse your original o2 sensor also
Old 09-24-2024 | 09:55 PM
  #64
QVQ37's Avatar
QVQ37
Engine swap
Okay this will be my first swap ever . Any pointers ? Will be pulling with engine hoist . & I saw info about injectors if anybody else has done this swap what all did you have to swap over . I’m including pictures of the motor im installing
Old 09-25-2024 | 07:39 AM
  #65
projectpanda13
install the powersteering pump from your G37. As you see with you new engine, there's no PS pump since the Q uses electric assist. Injectors are the same.
Just reuse your upstream O2 sensor from your g37 because if i remember, your harness has the rectangular grey plug and the Q uses a flat brown plug.
Old 10-12-2024 | 01:13 PM
  #66
QVQ37's Avatar
QVQ37
Okay so they guy ended up selling the motor I wanted and I ended up with another just like what I have but I’m running into a problem with the oil filter . Old motor has black cover with lines attached news one does not . Hoyt’s do I swap these over ?
eljoker
Future Models
19
05-30-2022 11:48 AM
reachout
General Tech Questions
38
06-27-2020 12:35 AM
AMai1215
09-13-2015 12:59 PM
SuicidalG37SGuy
09-10-2015 06:01 AM
Quick Reply: Engine compatibility between models? VQ37VHR
