Cleaned throttle bodies and now the rpm's don't drop very rapidly
Old 08-08-2013, 01:24 AM
Danjjacob
Danjjacob's Avatar
I pulled the throttle bodies and carefully cleaned out the carbon build up spraying the cleaner on the rag and wiping the insides of the throttle bodies. Snugged them back up and fired it up. Much smoother idle however after I started to drive it I notice the rpms do not drop between shifts (6MT) and will hover around 1200 when coming to a stop for a few seconds before finally settling down to around 900.
I tried the crazy idle reset by turning the car to on and pumping the gas pedal 5x in 5 seconds then holding it down for 20 seconds but it didn't change anything.
Any suggestions?
Thanks fellas
Old 08-08-2013, 06:28 AM
Sunny G
Sunny G's Avatar
I would guess there is a relearn procedure the car does automatically, but I'm not sure. What I would like to know is what cleaner did you use?
Old 08-08-2013, 11:19 AM
Can'tGme
Can'tGme's Avatar
There are a couple of relearns you have to do in order. You may not have done them correctly. I know it takes me a few tries to get it right.
Old 08-08-2013, 10:18 PM
Danjjacob
Danjjacob's Avatar
It was regular throttle body cleaner from PepBoys.
Thanks Can'tGMe I will give it another go. I tried it 3x but the "Service Engine Soon" light never did go off like the instructions says it should.
Old 08-14-2013, 01:56 AM
sukh79
sukh79's Avatar
figure it out ?? did you disconnect your battery before cleaning them. if not, do so, reconnect and fire up.
Old 08-14-2013, 11:30 AM
JerseyG37s
JerseyG37s's Avatar
if you mess with the electronic flapper when cleaning them youll probably need to replace them i have seen it all the time.... good luck the throttle body itself is around 900 bucks before install
superjoey
31
03-22-2023 11:56 PM
WolfSongX
Car Care & Detailing
05-10-2017 07:26 PM
JakeG37
08-02-2015 12:00 PM
Quick Reply: Cleaned throttle bodies and now the rpm's don't drop very rapidly
