Review EcuTek tune complete - solid gains on 2013 G37XS AWD Sedan
Old 07-30-2013, 03:55 PM
DJE44
DJE44's Avatar
Finally getting around to your questions and comments! It's been a week after the tune, and I'm still all smiles.
Nice gains on the dyno. How does it feel?
Incredible. Not much of a difference up to 3K RPM but its a tremendous boost above that. The best way I can describe it is like when you are stuffed up from a cold and how meds clear your nose up. She breathes so much better, just an amazing takeoff now.
Originally Posted by G37-Pearl
which dyno your car run this on ? op run & tuned on mustang dyno as in pic no.1
also there are too many variables to match same cars numbers
you need headers to complete your bolt on
It was an AWD Mustang Dyno, yes. Headers I'm on the fence about. I've heard little to no gains from an upgrade over OEM as Infiniti's are actually very well made.
Remember ECutek, and Uprev are only tools.
The brilliance is in the person using the tools.
Sure Ecutek can change cam/valve timing, but which tuner out there has
the brains to use it safely and effectively???
A street tune also is NOT about pure net power, its also drivability.
This is so spot on. The software surely does something, but the magic is with the installer / tuner. Vince is the MAN when it came down to it. He went above and beyond getting everything out of her.
Originally Posted by pebkac
Do you think your mods helped much with the gain? What about stock 2013 G37S sedan?
Not sure if spending the money is worth it with a stocker. A tune will only really benefit with performance mods IMHO. The more, the greater end result. In actuality, you are teaching your vehicle what improvements to run on now. Why would you tell it to re-learn stock setup?
Originally Posted by rza2042
Nice numbers! What was the temperature and humidity in the shop? Was weather correction taken into account with these results? Any chance you can post a printout instead of the screen shot?
It was pretty damn humid, but they had the fans going. Weather wasn't taken into consideration. That is a printout.
Originally Posted by chuckie311
he is talking about at the crank not the wheels!!!
Right! Now that would have been some crazy results.
Again, I'm still sold on what R/T said about EcuTek being the better tune software. I've seen so many UpRev dyno results with even better performance mods than mine (Gen3, TP's, etc.) and I'm way over their results. I know I sound like a fanboy, but just backing up what I've witnessed.
I'll be going in next week for a post-tune checkup and another dyno after 2 weeks of driving on the revamped ECU. I'll be sure to post those results as well.
Old 08-08-2013, 05:18 PM
chuckie311
Drop A Gear and Disappear
chuckie311's Avatar
so not true... you must not have seen this thread
NA: 342/275. Anyone higher? - Nissan 370Z Forum
30hp from headers
Old 08-08-2013, 05:25 PM
DJE44
DJE44's Avatar
I was going by what people have said about Stillen, which are available. Those Momentum headers are no longer made, unfortunately.
Old 08-08-2013, 08:25 PM
SS_FireHawk
SS_FireHawk's Avatar
Z1 makes shorties that are Momentum replica's, all the way down to using the same jig. Must buy DE TP's or HFC's though because of the flange. Those would be the only shortie headers I'd recommend.
For long tubes, PPE rules the roost. There is so much technology going into those headers, it's a laundry list:
409 mild steel or 304 option
multiple Jet Hot coating options including a 2000 degree ceramic black
Header primaries are equal length, with the length being tuned specifically to the VQ37VHR powerband
3/8" ported and sanded flanges
5" 15 degree merge collector
At the bottom of the collector it has a small choke point increaseing low and mid range with no loss on top, before transitioning out to 2.5"
headers are stepped from 1.75" to 1.875" increasing mid range and maintaining top end.
I'm biased... I own PPE's, and so do several race teams that use them on their Z's.
Fast Intentions also has a long tube header option that has good low and mid range, but top end is lacking compared to PPE's.
Outside of those 3 options, I wouldn't look at any other options unless you have $$$ to spend on some JDM ones. Doran racing is also coming out with their own, but the only thing we saw was the merge collector.
The following 2 users liked this post by SS_FireHawk:
ANMVQ (04-03-2014), DJE44 (08-09-2013)
Old 08-13-2013, 02:49 PM
chuckie311
chuckie311's Avatar
they sure are still made...just like firehawk said have to use DE parts or wait for the new flange...
Z1 Motorsports VQ Performance Headers
Old 01-19-2014, 06:17 AM
mezzo
Green Eyes!
mezzo's Avatar
DJE, any updates/thoughts on your EcuTek tune you can provide? Did you happen to have UpRev prior to EcuTek?
Old 01-20-2014, 07:56 PM
DJE44
DJE44's Avatar
No, I went right from stock to EcuTek. Wouldn't even consider UpRev after the gains I've had. Seems more people are following my steps too. I've even read some people getting better numbers stock than UpRev.
You bet your **** I'd do it all over again.
Old 01-25-2014, 05:26 PM
Elohel
Elohel's Avatar
God damn your car looks beautiful. I may have to pick up those same wheels.
Old 01-25-2014, 06:29 PM
malady
malady's Avatar
your making me change my mind about getting uprev
but no one seems to tune ecutek for our cars in central florida >_<
The only shop I can find does brz/frs
Old 01-25-2014, 09:59 PM
Darth Kinetic
Darth Kinetic's Avatar
Subscribed
Old 01-26-2014, 09:33 AM
DJE44
DJE44's Avatar
Much thanks. 20" Giovanna Killis in Matte Black. Fat 10.5's in the rear.
EcuTek tuners are a tough find, good ones especially. But they're worth it. RTTuning (where I went) has customers coming in on flatbeds from all over the country.
Old 03-29-2014, 02:24 PM
Jack10525
Jack10525's Avatar
DJE44,
How much were all the mods? Can you list them with a price for each?
Old 03-30-2014, 11:34 PM
RISKY GUY
RISKY GUY's Avatar
With 20s it's an impressive pull.
When mine was done via uprev I pulled 318/270 at the wheels.
Had 20s I was very happy with the before & after.
Ecu tek isn't big worldwide on this platform.
Was introduced to software when I had got the evo x mr.
Same car in Europe was making 400hp without breaking a sweat.
So, it's just a matter of tweaking the runs.
Seeing what they have done with other platforms, I am impressed.
This dyno plot power band curve is nice.
DJE44 (03-31-2014)
Old 03-31-2014, 01:16 PM
  #29
DJE44
DJE44's Avatar
Originally Posted by Jack10525
DJE44,
Check my garage, brother. Can't recall prices off hand, but shop around.
Old 04-03-2014, 10:48 AM
  #30
ANMVQ
ANMVQ's Avatar
Every time I read this I have to smile." I've even read some people getting better numbers stock than UpRev." So you know or have seen cars make more than 300WHP "Stock" ?
Just curious cause I made 262 WHP and 220WTRQ Stock, and 298WHP 233WTRQ tuned with UPREV I:E. An not knocking ECUTEK, I had is sitting in my house for over a month. the tuner went south on me so I retuned it. Have UPREV again just haven't tuned yet, Z tubes, and Exhaust.
G's
11-05-2023 12:01 PM
SLEV3N
General Tech Questions
10-17-2015 05:58 PM
sharmelan
08-25-2015 03:41 PM
drkashifa
08-15-2015 01:27 AM
Spicy_Kimchee
08-11-2015 09:10 AM
Quick Reply: Review EcuTek tune complete - solid gains on 2013 G37XS AWD Sedan
