Transmission DS & M Problem :(
Hey guys,
It have a problem with my Transmission which i don't know how to explain right. Also am not sure if I'm posting in the right place, direct me if I'm not, please.
Car Details:
Infiniti G37S Coupe 2009 model
Rear Wheel Drive - 7AT
Have had it almost for 4 years
Have driven it about 100,800km = 62,634 miles
The problem:
When I switch from D To DS mode the car will drive with no problems on DS mode for few minutes while shifting from gear 3rd to 4th to 5th and all the way to 7th. The car will shift back the mode to D, even though the shift **** is on DS. If I try to change the gears through the paddle shifter M which is placed in the Steering Wheel. The car wont shift and it stay on D.
I have no problems with the D mode at all the car does it's job automatically wonderfully with no issues. It is just DS and M Mode. If I switch off the car for like 15 or 30 minutes the DS and M mode will work for a few minutes and again will stuck on D mode automatically.
I took it to the dealer and they are asking me to pay about 4,356 US Dollars to replace a small part in the transmission, which I believe is an electronic part. The dealer report says there is an issue with the transmission programing, but no defect or issues as a mechanical part.
I have read, through the issue around here in the forums and I can't see any solutions. I have printed a PDF remap for the transmission and I didn't try it yet. I'll have to do it this weekend.
If anyone knows different solutions, let me know, please.
Car Details:
The problem:
It's the gear shifter, there's a sensor there that picks up whether it is on D or DS mode. I'm not sure you can replace just that sensor so you'll probably need to swap out the entire shifter assembly. 16,000 UAE dirhams is a little too much for that though, cheaper to get an MT swap for that money.
You need to replace the whole shifter assembly. This is the most probably the part you need to change: DEVICE ASSY-TRANSMIS 34901-JK60C (check the part number for your vehicle)
Infiniti Parts - Infiniti parts
Search myg37 and g35driver if you need more info.
Pretty easy DIY, just make sure you read the corresponding section in the service manual. Not quite sure which section it is of the top of my head.
Good luck!
Good luck!
The following 2 users liked this post by CarAddict:
Black Bird (07-18-2013),
Presto (07-26-2013)
Good luck!
Good luck!
Why wouldn't this be covered under the drivetrain warranty?
Good luck!
Good luck!
Your solution worked about 100%
4DRZ
Drivetrain
34
08-05-2021 10:02 AM
Msherburneg37xs
Intake and Exhaust
09-30-2015 06:39 PM
r0cketm0nkey
09-27-2015 01:34 PM
