Hydro-locked my car
Old 07-04-2013, 08:58 PM
  #46
buckets
buckets's Avatar
It does rev freely in gear on the road. The exhaust was nvr raspy before, I had the tune done prior to drowning my engine. I nvr knew the engine had a rev limit in park or neutral, can anyone confirm this? Im really worried about my transmissions hesitation in first gear. Ima see if theyll fix it but im still looking for a replacement car.
Edit: so after letting my car sit and cool off it seems like all the problems have gone away and it's driving and sounding like before (fingers crossed)
Old 07-04-2013, 10:26 PM
  #47
Received 4,943 Likes on 4,176 Posts
Yes, there is a rev limiter in park & neutral, prevents no-load over revving.
Old 07-04-2013, 10:47 PM
  #48
buckets
buckets's Avatar
good to know, thanks
Old 07-15-2013, 12:25 AM
  #49
MGold1211
MGold1211's Avatar
Damn, I was reading this thread and thought, hell I live in CT and we did get a ton of rain. I was worried about my R2C intake picking up water, but I didn't encounter any huge puddles. Hope the G gets squared away for you.
Old 07-15-2013, 12:31 AM
  #50
buckets
buckets's Avatar
yah best of luck to ya. my car is pretty much back to normal save some ridiculous first gear lag. WOT in 1st from a dead stop and it pulls away like it has 80 hp until it hits ~3k-3.5k rpm. running out of things to check to rectify the problem
Old 07-15-2013, 10:44 AM
  #51
SgtGoldy
SgtGoldy's Avatar
Damn man, I'm sorry to hear that.
Old 07-15-2013, 11:33 AM
  #52
JerseyG37s
JerseyG37s's Avatar
People in texas are buying the flood cars from NYC and Jersey and spending some serious coin to have them fixed and running....your situation stinks and im sorry but this would be the best timing to build the motor of your dreams unless youre leasing
Old 07-15-2013, 08:38 PM
  #53
buckets
buckets's Avatar
Nah I own it. Ima try and sort out the hesitation. Pull the plugs and check the gaps, then ill probly go back to the tuner and have him retune it and finally ill drain and refill the transmission. I already cleaned the mafs and tb's also I did the idle air relearning and throttle position sensor reset.
Thedbarz
33
02-09-2016 12:05 AM
SLEV3N
General Tech Questions
10-17-2015 05:58 PM
JoshB
10-15-2015 03:08 PM
MeatySock
08-14-2015 08:25 AM
350zrunnin12s
08-09-2015 09:55 PM
Quick Reply: Hydro-locked my car
