Help HFC's
Old 05-27-2013 | 09:48 PM
enronforme's Avatar
enronforme
HFC's
Probably should have posted this here a few days ago....
Installed AAM high flow cats last week- love them! Problem is the p0420 code. I'm going to try the non-fouler spark plug route for the 02 sensors- are there different sizes of non-foulers I need to be concerned with? What size do I need for an '08 g37 coupe (18mm?).<!-- google_ad_section_end -->
Got the non-foulers ok... my question now is does anyone have any experience on how many non-foulers were needed coupled together to get the sensor far enough away from the HFC airflow to not trigger the code? I know I'll need at least 2, but I might need 3 to get the 02 sensor far enough away. My concern is the AAM HFC's I have (try saying that 3 times fast) have the sensor pointing at a downward angle, so I'm worried the 02 sensors could be in harms way if I get them extended too far out. Any help or ideas from anyone is appreciated. Thanks!
Bob
Old 05-28-2013 | 11:28 AM
seymore4's Avatar
seymore4
Another opton is to get an Uprev tune.. you can disable those codes permanently
Old 05-28-2013 | 11:46 AM
Rad_Slinger's Avatar
Rad_Slinger
P0420 is a "catalytic converter bank 1" code.
Doesn't that mean the O2 sensor for passenger side cat is bad?
Old 05-28-2013 | 12:09 PM
seymore4's Avatar
seymore4
All it means is that the sensor detected something out of the ordinary, very common with HFC/TP
Rad_Slinger (05-28-2013)
Old 05-28-2013 | 05:03 PM
ttv36's Avatar
ttv36
Race, repair, repeat.
I used 2 nonfoulers when I had TPs and it seemed to work without an issue.
Old 05-29-2013 | 09:18 AM
enronforme's Avatar
enronforme
Thanks- will give it a try tonight.
2012G37
Intake and Exhaust
43
06-12-2024 11:35 PM
hamkha1ebay
10-03-2015 03:55 PM
hamkha1ebay
09-28-2015 03:38 PM
SON415
09-28-2015 06:49 AM
Crespo
09-26-2015 12:16 AM
