Were you able to figure it out? It should be pretty straight forward from the directions that came with. In the link you posted, you would pull off that little black box and connect the hose to the R2C and similar on the other side. On the passenger side I pulled off the existing vacuum line and routed it around the metal tubing (believe it was fuel line, but don't remember right now). I didn't use the provided tube. Check out this link for install, should hopefully help.
